Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=4aac3ebc-374d-4e7c-9d1b-629c23010d90 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: Gigabyte product: B550 AORUS ELITE v: N/A
Mobo: Gigabyte model: B550 AORUS ELITE v: x.x serial: <superuser required>
uuid: <superuser required> BIOS: American Megatrends v: F10 date: 09/18/2020
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3591 high: 3679 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3679
3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600 11: 3593
12: 3600 13: 3561 14: 3431 15: 3593 16: 3600 bogomips: 114989
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: eVga.com.
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-3
empty: DP-1, DP-2, HDMI-A-1, Unknown-2 bus-ID: 0a:00.0 chip-ID: 10de:1e84
display-ID: 0
Monitor-1: DP-3 res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2070
SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 2070 SUPER driver: nvidia v: 550.54.14 device-ID: 10de:1e84
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM 17.0.6)
Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
Device-3: HP HyperX SoloCast driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3
chip-ID: 03f0:078b class-ID: 0300
Device-4: Razer USA BlackShark V2 Pro
lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 1532:0528 class-ID: 0300
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
Local Storage: total: 1.36 TiB used: 41.62 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 42.9 C
scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 29.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 41.62 GiB (8.9%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.5 C mobo: 41.0 C
Memory: total: 32 GiB available: 31.28 GiB used: 8.46 GiB (27.0%)
Processes: 436 Power: uptime: 7h 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 tools: apt,apt-get,gnome-software pm: pacman
pkgs: 2100 libs: 570 tools: octopi,paru Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-15
Last full system update: 2024-03-18 ↻
I am afraid I have to point out (again) that this forum should be used for specific requests about Garuda and its tools.
We cannot handle generic requests about Linux.
If it can be of any help, a glfw package is available in Arch repo, so you don’t need to compile anything.
https://archlinux.org/packages/extra/x86_64/glfw/
Or if you are compiling with glfw, have you searched the internet?
As per new topic template, you should provide as much information as possible, otherwise it is unlikely that someone will try to help.
I asked because it may be garuda related. glfw never does that normally when in a project. Especially considering it came with garuda.
Just a shot in the dark…
Is this a 32bit application?
If so, maybe this might help (although flagged out of date)?
https://aur.archlinux.org/packages/lib32-glfw-wayland
It’s 64 bit, but i’ll try that. How do I use aur to install it?
Download Snapshot .tar.gz from AUR page link
Extract the PKGBUILD
Run ‘makepkg -si’ in terminal in the extracted directory
