I’m suddenly having issues with the whatsie-git WhatsApp client. It will receive (most) new messages but sometimes it’ll not load a new message. It is unable to send new messages - they just hang without sending. When trying to log out of whatsie, that process also hangs. When logging in again, the QR code to link the client doesn’t display (just keeps loading). Linking by mobile phone number does work but then the above-mentioned issues resume. It looks like it might be some kind of connection or API problem. Until a few days ago, whatsie-git worked flawlessly. Any help would be appreciated.
## whatsie-git
Fast Light weight WhatsApp Client based on Qt's WebEngine, With lots of settings and packed goodies
|URL|https://github.com/keshavbhatt/whatsie|
|Version|4.16.2.r0.gece2c55-1|
|Licenses|MIT|
|Provides|[whatsie](goto:whatsie)|
|Depends On|[qt5-base](goto:qt5-base) [qt5-declarative](goto:qt5-declarative) [qt5-location](goto:qt5-location) [qt5-webchannel](goto:qt5-webchannel) [qt5-webengine](goto:qt5-webengine)|
|Conflicts With|[whatsie](goto:whatsie)|
|Installed Size|44.99 MiB|
|Packager|Garuda Builder <team@garudalinux.org>|
|Architecture|x86_64|
|Build Date|Friday 25 October 2024 22:40:02 Central European Summer Time|
|Install Date|Wednesday 30 October 2024 09:06:47 Central European Standard Time|
|Install Reason|Explicitly installed|
garuda-inxi:
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=983f8cbe-fd3d-48e2-a068-52fc8d3e1126 rw rootflags=subvol=@
quiet resume=UUID=808f17a0-f0f6-4fec-b509-5d7fc3d2cba3 loglevel=3 splash
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 20NKS0UU2M v: ThinkPad T495
Mobo: LENOVO model: 20NKS0UU2M v: SDK0J40697 WIN serial: <filter>
part-nu: LENOVO_MT_20NK_BU_Think_FM_ThinkPad T495
uuid: 4fd7234c-308f-11b2-a85c-dac9ac5f22ff UEFI: LENOVO v: R12ET64W(1.34 )
date: 02/23/2024
ID-1: BAT0 charge: 36.4 Wh (85.0%) condition: 42.8/50.5 Wh (84.9%)
volts: 12.4 min: 11.5 model: SMP 02DL008 type: Li-poly serial: <filter>
status: not charging cycles: 713
Info: model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33535
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 06:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 53.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-2.1:4 chip-ID: 5986:2130
class-ID: 0e02
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d6 built: 2016 res: 1366x768
ratio: 16:9 modes: max: 1366x768 min: 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 18.1.8 DRM 3.59 6.11.5-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.2.5-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Lenovo driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0
port: 3400 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1:2
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
Local Storage: total: 238.47 GiB used: 58.61 GiB (24.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
lanes: 4 tech: SSD serial: <filter> fw-rev: L15P temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 306d 13h cycles: 2,195
read-units: 101,667,745 [52.0 TB] written-units: 46,626,657 [23.8 TB]
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 57.43 GiB (25.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 17.2 MiB (5.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 5.67 GiB used: 5.56 GiB (98.2%)
ID-2: swap-2 type: partition size: 8.8 GiB used: 1.16 GiB (13.2%)
System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): fan-1: 3200 fan-2: 3200
Memory: total: 6 GiB available: 5.67 GiB used: 4.14 GiB (73.0%)
Processes: 339 Power: uptime: 20h 46m states: freeze,mem,disk
reboot, suspend, test_resume image: 2.24 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1582 libs: 480 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
System install date: 2024-09-28
Last full system update: 2024-10-31 ↻
