When checking debug-events, it seemed to be registering the presses and releases at random intervals. I assumed it was a hardware fault and found a bunch of stuff under the keycap. Cleaning that did nothing and now I’m checking if this is a problem with the software, not the hardware. I fixed it last time the left ctrl key stopped working, but it seemed to just fix itself. What is the issue here?
Garuda-Inxi as usual
root=UUID=cd554b12-50c1-4d21-8dc3-75e81b1e0163 rw rootflags=subvol=@
Type: Laptop System: HP product: HP ZBook 17 G3 v: N/A
Mobo: HP model: 80D6 v: KBC Version 10.75 serial: <superuser required>
UEFI: HP v: N81 Ver. 01.45 date: 01/06/2020
ID-1: BAT0 charge: 30.0 Wh (40.3%) condition: 74.5/74.5 Wh (100.0%)
volts: 12.3 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
Info: model: Intel Core i5-6440HQ bits: 64 type: MCP arch: Skylake-S
desc: 1x6 MiB
Speed (MHz): avg: 3205 high: 3243 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 3243 2: 3238 3: 3127
4: 3214 bogomips: 20799
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM204GLM [Quadro M3000M] vendor: Hewlett-Packard
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:13fa
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-7:2 chip-ID: 05c8:0383 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1738 built: 2015 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:191b memory: 15.14 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 15 device: 0 type: integrated-gpu
name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:191b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: Quadro M3000M driver: nvidia v: 545.29.02 device-ID: 10de:13fa
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: Hewlett-Packard
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:4 chip-ID: 8087:0a2b
Local Storage: total: 1.14 TiB used: 129.59 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: THNSN5256GPUK
NVMe TOSHIBA 256GB size: 238.47 GiB block-size: physical: 512 B
fw-rev: 5KDA4103 temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3T0 scheme: GPT
ID-1: / raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
used: 61.13 GiB (25.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 68.46 GiB (7.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 237.97 GiB size: 237.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C pch: 52.0 C mobo: N/A
Processes: 286 Uptime: 1h 54m wakeups: 0 Memory: total: 16 GiB
available: 15.5 GiB used: 7.8 GiB (50.3%) Init: systemd v: 254
Packages: 2138 pm: dpkg pkgs: 2 pm: pacman pkgs: 2103 libs: 560
tools: octopi,paru pm: flatpak pkgs: 33 Shell: fish v: 3.6.1 default: Bash
v: 5.2.15 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-1):
System install date: 2023-07-21
Last full system update: 2023-11-11
Is partially upgraded: Yes
