Whatpulse AppImage refuses to launch on KDE Garuda Wayland. Issue does not occur on KDE Bazzite Wayland.
As run through terminal to get output. This is an error I’m unfamiliar with, seems to be caused by a font? It’s pretty simple, no matter what I do, starting Whatpulse seems to fail. I don’t have this issue with any other AppImages on Garuda nor do I have it on my other Linux Distro at the moment (Bazzite Wayland KDE)
`chmod +x whatpulse-linux-latest_amd64.AppImage `
`./whatpulse-linux-latest_amd64.AppImage `
`QFont::fromString: Invalid description 'Fira Sans,10,-1,5,400,0,0,0,0,0,0,0,0,0,0,1' `
`QFont::fromString: Invalid description 'FiraCode Nerd Font Mono,10,-1,5,400,0,0,0,0,0,0,0,0,0,0,1' `
`fuse: memory allocation failed `
`squashfuse 0.5.2 (c) 2012 Dave Vasilevsky `
`Usage: squashfuse [options] ARCHIVE MOUNTPOINT `
`(null) options: `
`-o offset=N offset N bytes into ARCHIVE to mount `
`-o subdir=PATH mount subdirectory PATH of ARCHIVE `
`-o notify_pipe=PATH named pipe that will receive 's' (success) `
`or 'f' (failure) when the mountpoint is ready `
`-o timeout=N idle N seconds for automatic unmount `
`-o uid=N set file owner to uid N `
`-o gid=N set file group to gid N `
`FUSE options: `
`-h --help print help `
`-V --version print version `
`-d -o debug enable debug output (implies -f) `
`-f foreground operation `
`-s disable multi-threaded operation `
`-o clone_fd use separate fuse device fd for each thread `
`(may improve performance) `
`-o max_idle_threads the maximum number of idle worker threads `
`allowed (default: -1) `
`-o max_threads the maximum number of worker threads `
`allowed (default: 10) `
`(null) options: `
`FUSE options: `
`(null) options: `
`FUSE options: `
`Can't open squashfs image: Bad address `
`Cannot mount AppImage, please check your FUSE setup. `
`You might still be able to extract the contents of this AppImage `
`if you run it with the --appimage-extract option. `
`See https://github.com/AppImage/AppImageKit/wiki/FUSE `
`for more information `
`execv error: No such file or directory`
Kernel: 6.18.8-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4b50f2bb-29e3-46db-902d-6f9025f83b73 rw rootflags=subvol=@
nvidia_drm.modeset=1
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A wm: kwin_wayland with: krunner
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
serial: part-nu: SKU uuid: dccab955-4204-f11a-eeb3-04421af1eeb2
Firmware: UEFI vendor: American Megatrends v: 5101 date: 07/31/2025
Info: model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3857 min/max: 567/4955 boost: enabled
base/boost: 3700/4950 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3857 2: 3857 3: 3857 4: 3857
5: 3857 6: 3857 7: 3857 8: 3857 9: 3857 10: 3857 11: 3857 12: 3857
13: 3857 14: 3857 15: 3857 16: 3857 17: 3857 18: 3857 19: 3857 20: 3857
21: 3857 22: 3857 23: 3857 24: 3857 bogomips: 177609
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-2,DP-3
off: HDMI-A-1 empty: DP-1 bus-ID: 0b:00.0 chip-ID: 10de:2684
Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1355x381mm (53.35x15.00")
s-diag: 1408mm (55.42")
Monitor-1: DP-2 pos: left res: mode: 2560x1440 hz: 144 scale: 100% (1)
dpi: 109 size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-3 pos: primary,right res: mode: 2560x1440 hz: 170
scale: 100% (1) dpi: 109 size: 597x336mm (23.5x13.23") diag: 685mm (26.97")
modes: N/A
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB
API: Vulkan v: 1.4.341 layers: 12 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 590.48.01
device-ID: 10de:2684 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.5-arch1.1 (LLVM
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 0b:00.1 chip-ID: 10de:22ba class-ID: 0403
lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Schiit Audio Modi 3+ driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 30be:1014
class-ID: 0102
Device-4: Logitech Yeti X driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-4:3
chip-ID: 046d:0aaf class-ID: 0300 serial:
API: ALSA v: k6.18.8-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: n/a (root, process) with:
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac:
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: down mac:
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp7s0 state: down mac:
IF-ID-1: wg0-mullvad state: unknown speed: 10000 Mbps duplex: full
mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 5.2
Local Storage: total: 9.18 TiB used: 5.48 TiB (59.7%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: fw-rev: 5B2QGXA7 temp: 34.9 C
SMART: yes health: PASSED on: 250d 16h cycles: 1,809
read-units: 5,062,680,084 [2.59 PB] written-units: 236,839,104 [121 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: fw-rev: 5B2QGXA7 temp: 27.9 C
SMART: yes health: PASSED on: 1y 159d 13h cycles: 2,370
read-units: 221,231,786 [113 TB] written-units: 133,500,384 [68.3 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: SU800 family: based SSDs
size: 1.86 TiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: fw-rev: 7A temp: 13 C
SMART: yes state: enabled health: PASSED on: 2y 48d 17h cycles: 2541
read: 21.91 TiB written: 28.73 TiB
ID-4: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU800
family: based SSDs size: 1.86 TiB block-size: physical: 512 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: fw-rev: 7A temp: 10 C
SMART: yes state: enabled health: PASSED on: 1y 167d 0h cycles: 1791
read: 13.96 TiB written: 20.09 TiB
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2FR102
family: BarraCuda 3.5 (SMR) size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: fw-rev: 0001 temp: 23 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 14021h+37m+45.366s
cycles: 2471 read: 23.62 TiB written: 8.62 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (99.89%) used: 1.66 TiB (91.1%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:7
used: 10.3 MiB (3.4%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:6
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (99.89%)
used: 1.66 TiB (91.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:7
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (99.89%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (99.89%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 62.7 GiB used: 513.6 MiB (0.8%)
System Temperatures: cpu: 46.0 C mobo: 23.0 C
Fan Speeds (rpm): cpu: 0
Memory: total: 64 GiB available: 62.7 GiB used: 10.65 GiB (17.0%)
Processes: 703 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.99 GiB services: org_kde_powerdevil,
Packages: 2378 pm: pacman pkgs: 2328 libs: 529 tools: octopi,paru,yay
pm: rpm pkgs: 0 pm: appimage pkgs: 0 pm: flatpak pkgs: 50 Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.9 running-in: konsole
inxi: 3.3.40
Garuda (2.12.3-2):
System install date: 2024-06-08
Garuda release: 240428
Last full system update: 2026-02-09
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
Windows dual boot: Yes
— System Health Check Report —
26/26 checks run in 0.65 seconds ⌛
Powered by garuda-health 🦅
— CRITICAL —
Kernels in /boot are invalid (do not match expected files) (fix available)
— LOW —
“Garuda” is not the current bootloader:
PackageKit is currently installed. PackageKit (Discover, GNOME Software) is not a supported method to manage packages on Garuda Linux.
(fix available)
