Strange issue where Whatpulse will not launch in Garuda GNOME Wayland. I’m saying it’s strange as I neither had this issue on ZorinOS GNOME Wayland or Garuda KDE X11 (and IIRC Wayland too)
Attempting to run it gives me this:
'/home/user/Downloads/whatpulse-linux-latest_amd64.AppImage'
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Looked for solutions on here, one recommended downgrading fuse2 to version 2.9.9-5 but that didn’t work for me
The only way I have been able to get it to run is with
QT_QPA_PLATFORM=xcb ./whatpulse-linux-latest_amd64.AppImage
As described by the error code, reinstalling has not worked. And this is highly suboptimal at best as I was hoping to have it autostart on launch and have it setup with either GearLever or AppImageLauncher, both of which I have no clue how to work with such parameters (I’ve made attempts, albeit unsuccessful ones)
Garuda-inxi below
Kernel: 6.13.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ff61de21-93b0-4584-9e16-c1427281220a rw rootflags=subvol=@
quiet rd.luks.uuid=96eee633-9578-4ee4-8c62-b5ad68fbd489
rd.luks.uuid=c400c574-90df-4399-b512-3e044c213a0e
resume=/dev/mapper/luks-c400c574-90df-4399-b512-3e044c213a0e loglevel=3
Desktop: GNOME v: 47.4 tk: GTK v: 3.24.48 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 47.0 Distro: Garuda base: Arch Linux
Type: Laptop System: Framework product: Laptop 16 (AMD Ryzen 7040 Series)
v: AJ serial: <filter> Chassis: type: 10 v: AJ serial: <filter>
Mobo: Framework model: FRANMZCP09 v: A9 serial: <filter>
part-nu: FRAGACCP0J uuid: 23447ac1-a6a5-ef11-bec7-235790800115 UEFI: INSYDE
v: 03.05 date: 11/13/2024
ID-1: BAT1 charge: 49.2 Wh (55.8%) condition: 88.2/85.1 Wh (103.6%)
volts: 15.0 min: 15.5 model: NVT FRANDBA type: Li-ion serial: <filter>
status: discharging cycles: 9
Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics socket: FP8 bits: 64
microcode: 0xA704107
Speed (MHz): avg: 1097 min/max: 400/4001 boost: disabled
base/boost: 4000/5250 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1097 2: 1097 3: 1097 4: 1097
5: 1097 6: 1097 7: 1097 8: 1097 9: 1097 10: 1097 11: 1097 12: 1097
13: 1097 14: 1097 15: 1097 16: 1097 bogomips: 127765
Device-1: Advanced Micro Devices [AMD/ATI] Navi 33 [Radeon RX 7600/7600
XT/7600M XT/7600S/7700S / PRO W7600] vendor: Framework driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n6 (6nm) built: 2023+
pcie: gen: 4 speed: 16 GT/s lanes: 8 ports: active: none
empty: DP-1,Writeback-1,eDP-1 bus-ID: 03:00.0 chip-ID: 1002:7480
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Framework
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-2
empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, DP-9, Writeback-2
bus-ID: c5:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 29.0 C
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
compositor: gnome-shell driver: dri: radeonsi gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 4096x2560 s-dpi: 96 s-size: 1084x677mm (42.68x26.65")
s-diag: 1278mm (50.32")
Monitor-1: eDP-2 model: BOE Display 0x0bc9 built: 2022 res:
mode: 4096x2560 hz: 165 scale: 100% (1) dpi: 306 gamma: 1.2
size: 340x220mm (13.39x8.66") diag: 407mm (16") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
gfx1103_r1 LLVM 19.1.7 DRM 3.60 6.13.4-zen1-1-zen) device-ID: 1002:15bf
memory: 7.81 GiB unified: no
API: Vulkan v: 1.4.303 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: N/A device-ID: 1002:15bf
surfaces: xcb,xlib device: 1 type: discrete-gpu name: AMD Radeon RX 7700S
(RADV NAVI33) driver: N/A device-ID: 1002:7480 surfaces: xcb,xlib
device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: corectrl x11: xdriinfo,
xdpyinfo, xprop, xrandr
vendor: Framework driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Definition Audio vendor: Framework driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640
vendor: Framework driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s lanes: 16 bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.4-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.7 status: n/a (root, process) with:
bus-ID: 05:00.0 chip-ID: 14c3:0616 class-ID: 0280
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:6 chip-ID: 0e8d:e616
Local Storage: total: 5.5 TiB used: 59.49 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Seagate model: ZP2048GV30002
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SUMSS000 temp: 27.9 C
SMART: yes health: PASSED on: 51 hrs cycles: 38
read-units: 148,715 [76.1 GB] written-units: 376,032 [192 GB]
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624361WD temp: 27.9 C scheme: GPT
SMART: yes health: PASSED on: 11 hrs cycles: 148
read-units: 1,151,949 [589 GB] written-units: 1,614,738 [826 GB]
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 59.49 GiB (3.2%)
fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
mapped: luks-96eee633-9578-4ee4-8c62-b5ad68fbd489
used: 772 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:6
used: 59.49 GiB (3.2%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-96eee633-9578-4ee4-8c62-b5ad68fbd489
ID-1: swap-1 type: partition size: 60.2 GiB used: 0 KiB (0.0%)
mapped: luks-c400c574-90df-4399-b512-3e044c213a0e
ID-2: swap-2 type: zram size: 54.73 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.8 C mobo: N/A
Fan Speeds (rpm): fan-1: 0 fan-2: 0
GPU: device: amdgpu temp: 29.0 C watts: 6.11 device: amdgpu temp: 29.0 C
mem: 36.0 C fan: 0 watts: 6.00
Memory: total: 56 GiB available: 54.73 GiB used: 5.56 GiB (10.2%)
Processes: 480 Power: uptime: 1h 17m states: freeze,mem,disk
suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 21.88 GiB services: gsd-power,upowerd
Packages: 1633 pm: pacman pkgs: 1618 libs: 505
tools: gnome-software,octopi,paru pm: flatpak pkgs: 15 Compilers:
gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
running-in: gnome-terminal inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-02-24
Last full system update: 2025-02-27 ↻
Relevant software: snapper tlp NetworkManager dracut
Windows dual boot: Yes
