What Kernel is every one using ? Im Trying out Mainline and it is very good
What Kernel is everyone using? Im Trying out Mainline and it is a very good
I have been trying out mainline I tried it on other DE and it looks like its stable
so I have another Question So Im Using MATE and it looks Like we match
but there are a few things that come with mate I don't like how can I change or remove them while doing a fresh install ?
  Kernel: 6.2.0-rc7-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
    root=UUID=0bcebc11-6ba9-4b23-8b4a-addbda934f51 rw [email protected]
    loglevel=3 ibt=off
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
    UEFI: American Megatrends v: 2601 date: 05/17/2022
  Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 4255 high: 5092 min/max: 800/5100 scaling:
    driver: intel_pstate governor: performance cores: 1: 5001 2: 5092 3: 4967
    4: 4985 5: 3800 6: 5002 7: 3800 8: 3800 9: 5039 10: 3800 11: 3800 12: 3800
    13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121639
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 49.0 C
  Display: x11 server: X.Org v: 21.1.7 compositor: marco v: 1.26.1 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
    built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
    (polaris10 LLVM 15.0.7 DRM 3.49 6.2.0-rc7-1-mainline) direct-render: Yes
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Sound API: ALSA v: k6.2.0-rc7-1-mainline running: yes
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.18 TiB used: 131.01 GiB (4.0%)
    model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
    rev: 211070WD temp: 33.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
    rev: 2B2QEXM7 temp: 45.9 C scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
    rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
    used: 131.01 GiB (56.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1214
  Processes: 363 Uptime: 49m wakeups: 0 Memory: 31.25 GiB
  used: 3.19 GiB (10.2%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1563
  pm: pacman pkgs: 1562 libs: 474 tools: gnome-software,octopi,pamac,paru
  pm: appimage pkgs: 1 pm: flatpak pkgs: 0 Shell: fish v: 3.6.0
  running-in: mate-terminal inxi: 3.3.25
Garuda (2.6.14-1):
  System install date:     2023-02-13
  Last full system update: 2023-02-13
You can't. Not during an install. You may be able to afterwards but that is highly subjective, especially since you have not said what you want to remove.
You have to look at each package's depends and what the impact will be. Some will be critical to the MATE desktop. Some applications added by the developer will not.
