Hey gang!
I'm using the newly released Asus Flow X16. There is a community build around writing custom software for Asus Laptops; I am using the custom kernel and ctls they have developed. (thats why some of my inxi info looks alien).
I am using Garuda Dragonized Gaming 2.6.6-1, installed with Nouveau drivers w/ manually installed Nvidia drivers.
Doing this, I was able to achieve all the functionality of Garuda and asusctl, EXCEPT for gpu-switching into integrated mode specifically.
I've ruled it down to something scanning the PCI bus and waking the dGPU, but have no idea what it is.
Does anyone have any idea what it might be? I'm a college student and could really use the extra battery life.
Thanks in advance.
Obligatory garuda-inxi
Kernel: 5.19.4-arch1-g14-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: ibt=off pm_debug_messages amd_pmc.enable_stb=1
amd_pmc.dyndbg="+p" acpi.dyndbg="file drivers/acpi/x86/s2idle.c +p"
BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=ce89ec47-6e0e-4cd5-9604-f44d17ebdb7f rw rootflags=subvol=@
resume=UUID=d5202c9f-8eca-4719-9469-62dc3af19619 loglevel=3
nvidia-drm.modeset=1
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Convertible System: ASUSTeK product: ROG Flow X16 GV601RM_GV601RM
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GV601RM v: 1.0 serial: <filter> UEFI: American
Megatrends LLC. v: GV601RM.303 date: 05/13/2022
ID-1: BAT0 charge: 87.2 Wh (100.0%) condition: 87.2/90.0 Wh (96.9%)
volts: 16.0 min: 16.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
Device-1: hid-0018:04F3:2FC3.0007-battery model: ELAN9008:00 04F3:2FC3
serial: N/A charge: N/A status: N/A
Info: model: AMD Ryzen 7 6800HS with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3571 high: 4785 min/max: 400/4785 boost: enabled
base/boost: 3200/4750 scaling: driver: amd-pstate governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3168 2: 3167 3: 3168 4: 3161
5: 3168 6: 3168 7: 3169 8: 4785 9: 3169 10: 3168 11: 4785 12: 3167
13: 3169 14: 4785 15: 3168 16: 4785 bogomips: 102247
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.65.01 alternate: nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max:
lanes: 16 ports: active: none empty: DP-6,HDMI-A-2,eDP-2 bus-ID: 01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, HDMI-A-1 bus-ID: 09:00.0 chip-ID: 1002:1681
Device-3: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 5-1:2 chip-ID: 0408:30c3 class-ID: fe01 serial: <filter>
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x8e9d built: 2021
res: 2560x1600 hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46")
diag: 406mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
OpenGL: renderer: AMD YELLOW_CARP (LLVM 14.0.6 DRM 3.47
5.19.4-arch1-g14-1) v: 4.6 Mesa 22.1.7 direct render: Yes
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio
bus-ID: 09:00.1 chip-ID: 1002:1640 class-ID: 0403
driver: snd_pci_acp6x v: kernel
alternate: snd_pci_acp3x,snd_rn_pci_acp3x,snd_pci_acp5x,snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.5 chip-ID: 1022:15e2
class-ID: 0480
bus-ID: 09:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.4-arch1-g14-1 running: yes
Device-1: MEDIATEK vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 14c3:7922
IF: wlp6s0 state: up mac: <filter>
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 13d3:3568 class-ID: e001 serial: <filter>
Local Storage: total: 953.87 GiB used: 42.63 GiB (4.5%)
model: 3400 MTFDKBA1T0TFH size: 953.87 GiB block-size: physical: 512 B
rev: P7MA001 temp: 27.9 C scheme: GPT
SMART: yes health: PASSED on: 16 hrs cycles: 30 read-units: 1,848,844
[946 GB] written-units: 796,141 [407 GB]
ID-1: / raw-size: 937.19 GiB size: 937.19 GiB (100.00%) used: 42.63 GiB
(4.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
(0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 937.19 GiB size: 937.19 GiB (100.00%) used: 42.63
GiB (4.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 937.19 GiB size: 937.19 GiB (100.00%) used: 42.63
maj-min: 259:2
ID-5: /var/tmp raw-size: 937.19 GiB size: 937.19 GiB (100.00%) used: 42.63
maj-min: 259:2
ID-1: swap-1 type: zram size: 14.89 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.38 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.2 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 0
Processes: 399 Uptime: 8m wakeups: 6 Memory: 14.89 GiB used: 4.19 GiB
(28.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 2007 lib: 554
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.20
e[1;34mGaruda (2.6.6-1):e[0m
e[1;34m System install date:e[0m 2022-09-03
e[1;34m Last full system update:e[0m 2022-09-06
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
