What is Hush?❓
In "Garuda Boot Options" (A handy utility, thanks team Garuda!) there is an option under Messages for Hush Grub (add hush).
I can not for the very life of me find documentation for that kernel parameter. What is it? What does it do differently from quiet? Is it a Batman thing?
Thank you, lovely people, for your time.
All it does is add (or remove) the quiet kernel parameter from the GRUB_CMDLINE_LINUX_DEFAULT= line in /etc/default/grub.
https://wiki.archlinux.org/title/silent_boot
quiet or quiet quiet ? :smiley:
I am not sure why that kernel parameter is on there twice! Interestingly, if you check "Regular Grub" in Garuda Boot Options it will remove them both, but if you re-check "Silent Grub" it only adds one back. :thinking: :joy:
It adds/removes quiet hush
I know what quiet does. What's hush for?
Oh! Does it make the user quiet during boot? :laughing:
Where are you seeing hush?
Are we looking at the same thing?
You may have an updated version...? :man_shrugging: The one I am looking at right now does not mention hush.
Is it setting up this file for you? ~/.hushlogin
Also touch ~/.hushlogin to remove the Last login message.
Hush little baby, don't say a word. Mama's gonna buy you a mockin' bird.
ksnip_20230307-221733
Hmm, is it possible it disables the bootsplash?
`ui->rb_limited_msg->setVisible(!ui->cb_bootsplash->isChecked());`
else if (line.startsWith("GRUB_CMDLINE_LINUX_DEFAULT=")) {
            ui->lineEdit_kernel->setText(line.remove("GRUB_CMDLINE_LINUX_DEFAULT=").remove("\"").remove("'"));
            if (line.contains("hush")) {
                ui->rb_limited_msg->setChecked(true);
You will have to test it out and let me know @Catra, since I don't have that one. :wink:
