Hey gang. Brand new Linux user. I've been distro hopping for a few weeks, and stumbled upon this amazing looking distro.
So far things have been working pretty nicely OOTB on most distros, except KDE. There seems to be some issue going on with my setup, and last night, Garuda was polite enough to let me know what the problem was. Something going on with Kwin. So I'm reading as much as I can, but so far, I've found nothing.
I ramble, forgive me. I really hope I can resolve this because for some reason Gnome just doesn't sit right with me, and I like the philosophy behind Garuda.
Locutus
January 31, 2023, 10:39am
2
Any chance of you posting specifics of what is happening and launch Konsole and enter grauda-inxi and paste the output here using 3 ~ above the posted Konsole output and 3 ~ after you Konsole output.
tbg
January 31, 2023, 4:33pm
3
You could try running a Wayland session instead of X11. Search the forum for how to install and run Wayland on KDE.
To be honest I wouldn't make that suggestion without know if they're running nVidia or AMD / ATI for their video.
tbg
January 31, 2023, 4:50pm
5
It's only for testing purposes, the session can be changed easily at the login screen.
You are correct though, the user needs to post the output of garuda-inxi
to receive further assistance.
I have an Intel Xe integrated card. Not sure exactly what that would fall under.
tbg
February 1, 2023, 5:26pm
8
Your garuda-inxi
output has been requested 3 times already (this is the 4th mention), if your next post does not include your required garuda-inxi
, then this thread will be locked until you have provided this.
You can edit your original post (OP) by hitting the pencil icon at the bottom of your first post and paste in your garuda-inxi
. We try to assist all users here, but the users that respect our forum's rules get priority assistance.
Please comply with all requests for information when asking for assistance. You will wear out forum assistants patience very quickly if you come off as uncooperative, (last warning).
alexjp
February 1, 2023, 5:35pm
9
also @gloriousbeardguy , garuda-inxi
is just a terminal app that prints your computer specs, so that people can help you, it isn't dangerous in any way.
without it, we would be just guessing things!
The OP doesn't have a way that I can edit it. Here's the requested garuda-inxi.
Thanks for humoring me. I'm attempting to learn quickly.
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_TALON quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: Framework product: Laptop (12th Gen Intel Core) v: A6
Mobo: Framework model: FRANMACP06 v: A6 serial: <superuser required>
UEFI: INSYDE v: 03.05 date: 08/23/2022
ID-1: BAT1 charge: 50.8 Wh (95.0%) condition: 53.5/55.0 Wh (97.2%)
volts: 16.1 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: discharging cycles: 3
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+ process: Intel 7 (10nm
ESF) family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x421
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2579 high: 4400 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: performance cores: 1: 2500 2: 2500 3: 2500
4: 2500 5: 4400 6: 2500 7: 1871 8: 2500 9: 2500 10: 2500 11: 2500
12: 2500 13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79872
Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:46a6
Screen-1: 0 s-res: 2256x1504 s-dpi: 96 s-size: 596x397mm (23.46x15.63")
s-diag: 716mm (28.19")
Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res: 2256x1504
hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48")
diag: 343mm (13.5") ratio: 3:2 modes: 2256x1504
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: a6:00.0 chip-ID: 8086:2725
IF: wlp166s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 2.84 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 620281WD
temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: USB DISK 3.2
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 114.61 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: swap-1 type: zram size: 31.06 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: N/A
Processes: 327 Uptime: 3m wakeups: 166 Memory: 31.06 GiB used: 3.34 GiB
(10.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1844 libs: 511
Garuda (2.6.8-1):
System install date: 2023-02-01
Last full system update: 2023-02-01 ↻
SGS
February 1, 2023, 9:19pm
12
Hi,
I edit your text, please use
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text in the view. Move the mouse pointer over it in the upper right corner.
It looks like you didn't install it yet. Are you having trouble getting through the installer?
tbg
February 2, 2023, 1:03am
14
This is very important.
The above description is of little help in trying to diagnose your issue. If there was some kind of error message onscreen then please write down exactly what the message was and post it on the forum. Please do not post pictures of a one sentence onscreen error message.
Do you experience a complete freeze when this happens?
Is it possible to move your mouse when this happens?
Can you use your keyboard when this happens?
We need far more information from you to be of any assistance. Help us to help you.
I had it installed. I ran it from a live usb to get the requested info.
The entire system froze for a good 10-20 seconds, and I was about to reboot.
When it unlocked from the freeze, I had about 15 error messages saying that the Kwin Windows Manager had restarted.
All Windows animations were gone after that. I’ll spend some time and reinstall it tonight and see if I can get the same error, and document what I was doing and what programs were running.
root=UUID=65ee50aa-b516-4ac4-ab2b-af7af33bda80 rw rootflags=subvol=@
resume=UUID=90c41179-3b87-4e64-9f06-e277ce993c3d loglevel=3
ID-1: BAT1 charge: 52.0 Wh (97.4%) condition: 53.4/55.0 Wh (97.0%)
volts: 17.6 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
status: charging cycles: 3
microcode: 0x421
Speed (MHz): avg: 2200 high: 2500 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 752 2: 2500 3: 851
4: 2500 5: 1110 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.7
hz: 60 dpi: 201 gamma: 1.2 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
Local Storage: total: 2.73 TiB used: 11.56 GiB (0.4%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
rev: 620281WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: USB DISK 3.2 size: 931.51 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 11.56 GiB (0.6%)
used: 11.56 GiB (0.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: swap-2 type: partition size: 34.17 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 339 Uptime: 40m wakeups: 241 Memory: 31.06 GiB
used: 3.38 GiB (10.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1153
libs: 308 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
Updated inxi after reinstalling. I played around for about an hour and a half, and couldn't replicate the issue. Could there possibly been some problem during install I didn't know about?
alexjp
February 5, 2023, 3:27am
17
weird stuff...
well ... the freezing of 10-20 seconds was probably the coredumps being generated (info on the errors being automatically generated).
So you did update after installation and now can't replicate? could there be some issue with the current versions you were in when having issues, and with the update, the new versions have it working properly?
I wish I knew. I don’t know enough to try and figure out what happened. I’ve had the same freezing issues on a couple different distros.
Bro
February 8, 2023, 10:50pm
19
That indicates either machine or operator error.
