What file system should I use for backup with Clonezilla
Hello Garuda users.
So far I have used BTRFS on Garuda on internal extra hard drive of my insatallation, but is it a good idea or should I use ext4 or another file system?
I am aware that I can use snapshot, but I prefer to use both waist belt and braces
  Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=ff14df11-1857-4590-8e3d-20efe22b14f4 rw rootflags=subvol=@
    mitigations=off quiet quiet splash rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3 ibt=off
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F20
    date: 10/25/2022
  Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
    microcode: 0x2C
  Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
    cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
    L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 2407 high: 4544 min/max: 800/4800:4900:3600 scaling:
    driver: intel_pstate governor: performance cores: 1: 1172 2: 1053 3: 4544
    4: 2100 5: 4525 6: 2100 7: 1274 8: 2100 9: 801 10: 2648 11: 2694 12: 2100
    13: 2100 14: 2100 15: 4500 16: 2100 17: 2100 18: 3599 19: 2100 20: 2448
    bogomips: 84480
  Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
    ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 compositor: marco v: 1.26.1 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: HDMI-A-3 mapped: HDMI-3 model: ASUS VP248 serial: <filter>
    built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
  API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel UHD Graphics 770
    (ADL-S GT1) direct-render: Yes
  Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  Local Storage: total: 2.73 TiB used: 104.74 GiB (3.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 type: SSD serial: <filter> rev: SBJ00101 temp: 30.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
    type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
    used: 104.74 GiB (11.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 125.58 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 27.0 C mobo: N/A
  Processes: 394 Uptime: 2h 13m wakeups: 0 Memory: 125.58 GiB
  used: 5.16 GiB (4.1%) Init: systemd v: 253 default: graphical
  pkgs: 1729 libs: 389 tools: octopi,pamac,paru Shell: Bash v: 5.1.16
  running-in: terminator inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2023-01-31
  Last full system update: 2023-02-22
If you are cloning a disk or partition with Clonezilla, I don’t think you have much choice on the filesystem. :face_with_monocle:
Making backups in addition to the snapshots is a good instinct, and using ext4 for the backup filesystem is fine if you want to introduce some filesystem diversity. Good old rsync works well for this, or a tool like Borg is reliable and well-liked in the community. Vorta gives Borg an easy-to-use GUI which is worthy of consideration: https://vorta.borgbase.com
Another consideration is backing up your snapshots to an external drive with Btrfs send/receive, or a tool like https://github.com/digint/btrbk.
