Weird sound behavior
I did my weekly update today on my 3 Garuda machines this morning and now my sound is no longer working on any of them.
The 3 computers are a desktop and 2 HTPCs.
Desktop inxi output:
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=89bff1a7-521e-4982-a6ca-a17250fb7b4e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 2803 date: 04/27/2022
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4203 high: 4257 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4249 2: 4241
3: 4250 4: 4244 5: 4249 6: 4219 7: 3600 8: 4249 9: 4250 10: 4250 11: 4250
12: 4246 13: 4257 14: 4218 15: 4249 16: 4227 bogomips: 115195
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0a:00.0
chip-ID: 1002:7340 class-ID: 0300
gpu: amdgpu d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-3 pos: primary,top-left res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.0-devel
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi
navi14 LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:7340
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv
v: 24.2.0-devel (git-9945f9e8d3) device-ID: 1002:7340
17.0.6 256 bits) driver: mesa llvmpipe v: 24.2.0-devel (git-9945f9e8d3)
(LLVM 17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab38
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
Local Storage: total: 4.32 TiB used: 2.39 TiB (55.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FPK002T
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SN10932 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Smart Modular Tech.
model: SHGP31-500GM-2 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 41061C20 temp: 44.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Crucial model: CT1000P1SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR021 temp: 43.9 C
ID-4: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240M500SSD1
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: MU03 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Mushkin model: MKNSSDS2960GB
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 8A0 scheme: GPT
ID-1: / raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
used: 105.88 GiB (24.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
used: 29.7 MiB (9.9%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-3: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 442.1 GiB (47.5%) fs: btrfs dev: /dev/nvme2n1p1 maj-min: 259:3
ID-4: /var/log raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.04 GiB size: 431.04 GiB (100.00%)
ID-1: swap-1 type: zram size: 46.95 GiB used: 94.6 MiB (0.2%)
ID-2: swap-2 type: partition size: 34.43 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:7
System Temperatures: cpu: 53.4 C mobo: N/A gpu: amdgpu temp: 46.0 C
mem: 0.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1367
Memory: total: 48 GiB available: 46.95 GiB used: 11 GiB (23.4%)
Processes: 438 Power: uptime: 3h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 18.74 GiB services: org_kde_powerdevil,upowerd
Packages: 2808 pm: pacman pkgs: 2786 libs: 620 tools: octopi,paru
pm: flatpak pkgs: 22 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: yakuake inxi: 3.3.35
System install date:     2022-07-10
Last full system update: 2024-07-02
Intel HTPC inxi output:
root=UUID=a07c6c44-c09e-40b8-b1fc-9a75d33d52c1 rw rootflags=subvol=@
Type: Laptop Mobo: AMI model: Intel serial: <superuser required>
part-nu: G5E6 uuid: <superuser required> UEFI: American Megatrends
v: Intel J4115 Ver:1.02 date: 09/24/2020
Info: model: Intel Celeron J4115 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 1 microcode: 0x42
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1124 high: 1634 min/max: 800/1800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1634 2: 1120 3: 945
4: 800 bogomips: 14284
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: HDMI-A-1
empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Monitor-1: HDMI-A-1 res: 3440x1440 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 600 (GLK 2)
device-ID: 8086:3185 memory: 3.49 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics 600 (GLK 2) driver: mesa intel v: 24.1.2-arch1.1
device-ID: 8086:3185 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 17.0.6 128 bits) driver: mesa llvmpipe
v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0403
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlo2 state: up mac: <filter>
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
wpa_supplicant
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4
Local Storage: total: 119.24 GiB used: 60.61 GiB (50.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Ramsta model: SSD128GBS800
tech: SSD serial: <filter> fw-rev: 3A0 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 60.61 GiB (51.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.15 GiB used: 2.45 GiB (34.3%)
Processes: 215 Power: uptime: 4h 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.85 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1367 libs: 386 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: yakuake
inxi: 3.3.35
System install date:     2023-11-27
AMD HTPC inxi output:
root=UUID=1169616d-e310-43fa-b9de-38b24d9246c1 rw rootflags=subvol=@
resume=UUID=80ee8fbd-199a-4611-bd4c-25e5b1915de0 loglevel=3 ibt=off
Type: Laptop Mobo: N/A model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 1.08_P2C10M3_AMILogo
date: 11/12/2021
Info: model: AMD Athlon 300U with Radeon Vega Mobile Gfx bits: 64
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2588 high: 2593 min/max: 1400/2400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2590 2: 2593
3: 2581 4: 2588 bogomips: 19163
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-1
empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300
temp: 63.0 C
Monitor-1: DP-1 res: 1707x960 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 3 Graphics
(radeonsi raven2 LLVM 17.0.6 DRM 3.57 6.9.7-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 3 Graphics (RADV RAVEN2) driver: mesa radv v: 24.1.2-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Realtek
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 8087:0a2a
Local Storage: total: 119.24 GiB used: 64.87 GiB (54.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Netac model: S535N8 128GYN
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-1: / raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
used: 64.87 GiB (58.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 596 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
ID-4: /var/log raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 110.15 GiB size: 110.15 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.74 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 63.5 C mobo: N/A gpu: amdgpu temp: 63.0 C
Memory: total: 6 GiB note: est. available: 5.74 GiB used: 2.98 GiB (51.9%)
Processes: 232 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.26 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1441 libs: 406 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26 running-in: yakuake
inxi: 3.3.35
System install date:     2022-06-16
The desktop is connected to a soundbar with an optical cable from the soundcard build into the motherboard. The AMD HTPC is sending sound to the TV it’s connected to via a DP to HDMI adapter that is on the supported list for CEC controls. The Intel HTPC is using a bluetooth speaker.
After the update I tried to watch a video on the AMD HTPC in kodi, the UI sounds worked, but the video sounds didn’t, when I went to the sound settings the sound would sometimes play while the pop-up had focus, but sometimes I’d have to change the profile. But when I go back to kodi sound does not work. I tried with both the Linux-Zen kernel and the Linux-LTS kernel on the AMD HTPC, I also tried with both wayland and X11 on plasma, then I installed a minimal gnome desktop.
I then tried on my desktop and sound doesn’t work at all when the profile is set to digital stero output, I have a 2.1 channel sound bar, but it does work in most things with digital stero out + analog in. Kodi has the same problem where it only plays when the sound settings is active, but on the desktop it get’s some weird feedback, that stops about 15 seconds after kodi closes.
On the Intel HTPC it also has the same issue where there is no sound in kodi unless the sounds settings is active.
I tried using a snapshot to go back to a working system, but the systems hang on Starting Terminate Plymouth Boot Screen.
I’m at a loss for what to try next…
I am no expert, but I would suggest Garuda Assistant audio settings:
There was an update for Pipewire a few days back, maybe it had a regression. Try PulseAudio.
Switching to pulse gave me a device unavailable error, and swtiching back to pipewire said there was a corrupt package. Unfortunately redownloading the corrupt package didn’t fix anything :confused:
I did find a workaround, if I pin the Audio Volume popout the sound works :person_shrugging:
I have the same issue, two AMD systems, same behavior.
I’ve been on vacation for the last 10 days, you still have this problem?
No, one of the updates fixed it for me!
Why update all three machines at the same time? You are tripling your chances of encountering a serious bug that could potentially prevent booting or being able to login.
It would seem to make far more sense to update once per week on your least critical machine. After updating this one test machine always be sure to reboot to make sure there are no serious show stopping bugs.
After you’ve used your testing machine for a day and encountered no serious bugs, then proceed with updating your other machines. This simple update strategy could save you a lot of big headaches when a very serious bug makes it down the pipe. You can’t rely on a snapshot to always save your ass. Better safe than sorry I figure.
IDK, been doing this for a few years and not had anything like this happen before. I don’t really use sound on my main machine, so didn’t catch the bug before updating the others, and last time I had an issue the snapshots worked.
Well by that logic, why take precautions in the height of a pandemic. If you never got Covid bad before, I guess there’s nothing to worry about right? Sorry, but that seems like a rather poor mentality if one wants to remain heathy.
Same with a computer. Don’t do risky things and Linux is super safe. If you read the Arch forums daily, chances are a major bug will not catch you by surprise. Otherwise it pays to play it safe. Unless you are one of the rare individuals that backs up all data on all machines on at least an hourly basis, you should always be concerned about the potential for a catastrophic failure.
I guess if you have spent no time customizing your machine, and all you use it for is watching cat videos on YouTube, then why worry about anything. :smiley:
I guess I’m done here, I’ll find a new distro.
I’d say that’s a bit of an overreaction to my admittedly flippant posting of a Bobby Ferrin video. I know it’s a song that can give you a serious ear worm, but certainly not extreme enough to want to switch distros.
C’mon dude chill.
Why should I stick around when the garuda team insults me when I have an issue and the snapshots are broken so I can’t roll back to a working state?
I was not trying to insult you I just have a different sense of humour than most people.
Arch is a rolling distro, with that comes a certain amount of risk. The risk of potential breakagres when updating is offset by having access to all the latest and greatest software as it becomes available.
Some people are suited to a rolling distro and others are not.There’s nothing wrong with static distros, it’s just not my cup of tea. If you’re more suited to a static distro that’s fine. Use whatever you feel most comfortable with.
Garuda is pretty upfront about this. Snapshots are not a substitute for a comprehensive backup strategy. Backups save your butt, snapshots are a handy feature to have, (nothing more).
Please do not use a rolling release if you do not enjoy repairing your system, the benefits of the latest software go hand in hand with spontaneous problems of any kind.
I found the advice on how to prevent such problems very helpful.
Personally, I have at least two different DEs on my computers so that I can carry out repairs via chroot without having to do this via USB live ISO.
A good backup procedure of important data lets me sleep peacefully.
I’ve been running an arch based distro for over 10 years. I learned about gardua about 4 yeas ago and swtiched because of the built in snapshots. I understand the risks. It was a minor inconvenience on my main system, but a show stopper for the media PCs, the problem was resolved before anyone from the garuda team looked at this.
But it’s time for me to move to a system where the team doesn’t insult those who experience problems and ask for help.
All of my important stuff has a backup on my NAS and in the cloud.
No one will stop you.
What’s funny to some is a deadly insult to others.
You shouldn’t put that on the gold scale in an international forum. Especially since it was explained to you how it was meant.
I’m glad to hear you do regular backups that’s great. What I am failing to understand is why you are so upset that the snapshot feature let you down if you keep full system backups.
Snapshots are not a replacement for backups, Garuda has been saying this since day one. So, it’s really not the distros fault if a snapshot occasionally cannot restore a system as that’s just the nature of the beast. Snapshots are simply not 100% reliable.
I’m sorry if you’ve felt insulted by anything I’ve posted here, but I personally don’t feel I posted anything that was rude or antagonistic in any way. I guess we will simply have to agree to disagree if that’s how you feel about it.
Arch is the king of distros, so you can never go wrong there if that’s what you’d rather use. Best of luck with whatever you choose. :wave:
I was reporting an issue. Calling someone an antivaxxer for reporting an issue is mean, and when it’s coming from an official member of the team it comes across as them dismissing people actually have issues and that this is not a place to seek help. Then rather than actually apologizing for insulting me they just dismissed it as a joke.
The hard part of all this, is that I enjoy using garuda, it meets my needs. But I don’t want to support people who insult others for reporting issues and seeking help.
I in no way said that. You are totally twisting my words now.
Now I am going to say something that could legitimately be taken as an insult if you so choose, because you seem to be looking a reason to be insulted. You need to get a thicker skin pal. If you are really so upset by my prior posts then I don’t know how you’ll make it through life with such over sensitivity issues. I come from a much earlier generation where men did not buckle so easily under the slightest bit of criticism and act like it was something so traumatic as to cause PTSD.
BTW, both of you please show me in anywhere in my posts that I called anyone an antvaxxer or even mentioned the word vaccination. You are both inserting your own interpretations and misrepresenting what I said.
@tbg never said anything about being anti-vaxxer or making anyone out to be an idiot. So calm down both of you @theboomboomcars and @bristlenosepleco.
