Weird problems with zen3 kernel
  Kernel: 6.7.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=a613e82f-ac23-44cf-bcab-a64bc638556e rw rootflags=subvol=@
  Desktop: MATE v: 1.26.2 wm: marco v: 1.26.2 with: mate-panel
    tools: xscreensaver,xscreensaver-systemd avail: xautolock vt: 7 dm: LightDM
  Type: Desktop System: Micro-Star product: MS-7C56 v: 2.0
  Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
    Megatrends LLC. v: A.E0 date: 07/03/2023
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540e
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3688 high: 4173 min/max: 2200/4650 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
    3: 3700 4: 4173 5: 3600 6: 3700 7: 3595 8: 3597 9: 3598 10: 3600 11: 3700
    12: 3600 bogomips: 88801
    vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 2d:00.0
    chip-ID: 1002:73df class-ID: 0300
    compositor: marco v: 1.26.2 driver: X: loaded: amdgpu
  Monitor-1: DP-1 mapped: DisplayPort-0 model: 24E6C serial: <filter>
    built: 2023 res: 1920x1080 dpi: 93 gamma: 1.2 size: 522x294mm (20.55x11.57")
    diag: 599mm (23.6") ratio: 16:9 modes: max: 1920x1080 min: 720x400
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.2
    navi22 LLVM 17.0.6 DRM 3.57 6.7.9-zen1-1-zen) device-ID: 1002:73df
    memory: 11.72 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 12 device: 0 type: discrete-gpu
    name: AMD Radeon RX 6700 XT driver: amd v: 2024.Q1.2 (LLPC)
    device-ID: 1002:73df surfaces: xcb,xlib
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
    bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.7.9-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
  IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 78.4 TiB used: 46.93 TiB (59.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 1.86 TiB block-size: physical: 512 B
    fw-rev: VC2S038E temp: 46.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE150 size: 4.55 TiB
    block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
    rpm: 7200 serial: <filter> fw-rev: FP2A scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: KLEVV model: NEO N610 SSD 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 7D scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST8000DM004-2U9188
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400M8120G
    tech: SSD serial: <filter> fw-rev: 61E1 scheme: MBR
  ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: Backup+ Hub BK
    size: 9.1 TiB block-size: physical: 4096 B logical: 512 B type: USB rev: 3.1
    spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: D781
  ID-7: /dev/sdf maj-min: 8:80 vendor: Utania model: OOS12000G
    size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
    serial: <filter> scheme: GPT
  ID-8: /dev/sdg maj-min: 8:96 vendor: Seagate model: Backup+ Hub BK
    fw-rev: D781 scheme: GPT
  ID-9: /dev/sdh maj-min: 8:112 vendor: Seagate model: Backup+ Hub BK
  ID-10: /dev/sdi maj-min: 8:128 vendor: Western Digital
    model: WD50NMZW-59BCBS0 size: 4.55 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 4800 serial: <filter> fw-rev: 4004 scheme: GPT
  ID-11: /dev/sdj maj-min: 8:144 vendor: Western Digital
    model: WD50NDZW-11A8JS0 size: 4.55 TiB block-size: physical: 4096 B
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
  ID-12: /dev/sdk maj-min: 8:160 vendor: Hitachi model: HUH721010ALE601
    size: 9.1 TiB block-size: physical: 4096 B logical: 4096 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
    serial: <filter> fw-rev: 0209 scheme: GPT
  ID-13: /dev/sdl maj-min: 8:176 vendor: Seagate model: Backup+ Hub BK
    rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: D785 scheme: GPT
  ID-1: / raw-size: 76.4 GiB size: 76.4 GiB (100.00%) used: 45.57 GiB (59.6%)
    fs: btrfs dev: /dev/sdd2 maj-min: 8:50
  ID-2: /boot/efi raw-size: 300.4 MiB size: 299.8 MiB (99.80%)
    used: 584 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49
  ID-3: /home raw-size: 7.28 TiB size: 7.28 TiB (100.00%)
    used: 1.88 TiB (25.8%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
  ID-4: /var/log raw-size: 76.4 GiB size: 76.4 GiB (100.00%)
    used: 45.57 GiB (59.6%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50
  ID-5: /var/tmp raw-size: 76.4 GiB size: 76.4 GiB (100.00%)
  ID-1: swap-1 type: zram size: 62.72 GiB used: 745.5 MiB (1.2%)
  System Temperatures: cpu: 53.6 C mobo: N/A gpu: amdgpu temp: 59.0 C
    mem: 56.0 C
  Memory: total: 64 GiB note: est. available: 62.72 GiB used: 4.94 GiB (7.9%)
  Processes: 409 Power: uptime: 3h 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.08 GiB services: mate-power-manager,upowerd
  Packages: 1768 pm: pacman pkgs: 1763 libs: 547 tools: octopi,paru,yay
    pm: flatpak pkgs: 5 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
    default: Bash v: 5.2.26 running-in: mate-terminal inxi: 3.3.33
Garuda (2.6.23-1):
  System install date:     2023-09-08
  Last full system update: 2024-03-09 ↻
Using the zen3 kernel, the 6.7.9 version had weird behavior. My terminal window shrank, and Firefox kept crashing. Rebooted with the default zen kernel and all is fine.
Just reboot, and I move it to MATE
