Hello everyone, I have an issue with my OS where the system will "freeze". By this, I mean that the mouse randomly is not allowed while I can use the keyboard to navigate around just fine. The weird this is that when I go from tty7 to tt6 using ctrl+alt+f6 then back to tty7 using ctrl+alt+f6, the issue goes away for a random amount of time, then it comes back and I have to keep repeating the process.
I do currently have a different kernel installed, and I have also had the same issue on the zen kernel. The USB mouse that I have plugged in and the laptop trackpad are both affected.
Any help that you could offer is appreciated, thank you.
Kernel: 6.0.9-272-tkg-cfs arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: intel_pstate=passive BOOT_IMAGE=/@/boot/vmlinuz-linux60-tkg-cfs
root=UUID=e9416402-e069-4d4e-bb01-f1e3bae3f883 rw rootflags=subvol=@
quiet
cryptdevice=UUID=1949db2f-9711-4773-a682-2b44dbeb8333:luks-1949db2f-9711-4773-a682-2b44dbeb8333
root=/dev/mapper/luks-1949db2f-9711-4773-a682-2b44dbeb8333 quiet
resume=/dev/mapper/luks-b2ac9071-968f-49db-97a3-319c12e45768 loglevel=3
splash
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Strix G712LV_G712LV v: 1.0
Mobo: ASUSTeK model: G712LV v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G712LV.311 date: 01/08/2021
ID-1: BAT0 charge: 57.4 Wh (98.5%) condition: 58.3/66.0 Wh (88.4%)
volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 5
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4983 high: 5000 min/max: 800/5000 scaling:
driver: intel_cpufreq governor: performance cores: 1: 5000 2: 4800 3: 5000
4: 5000 5: 5000 6: 5000 7: 5000 8: 5000 9: 5000 10: 5000 11: 5000 12: 5000
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
dri: iris gpu: i915 display-ID: :0.0 screens: 1
Monitor-1: eDP-1 model: LG Display 0x065b built: 2019 res: 1920x1080
hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics (CML GT2)
direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
Sound API: ALSA v: k6.0.9-272-tkg-cfs running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 7.74 TiB used: 1.39 TiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 52.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Extreme 55AE
size: 3.64 TiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 307F scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba
model: External USB 3.0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 5438
ID-1: / raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
used: 164.86 GiB (35.9%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-1949db2f-9711-4773-a682-2b44dbeb8333
used: 752 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-4: /var/log raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 15.2 MiB (0.1%)
ID-2: swap-2 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
mapped: luks-b2ac9071-968f-49db-97a3-319c12e45768
System Temperatures: cpu: 59.0 C pch: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2900
Processes: 378 Uptime: 17m wakeups: 1 Memory: 15.41 GiB
used: 4.74 GiB (30.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1729
pm: pacman pkgs: 1712 libs: 514 tools: pamac,paru pm: flatpak pkgs: 17
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-07
Last full system update: 2022-11-18 ↻
Failed units: vboxadd.service
