Hey there, I’ve been using garuda linux for a little over 1 month and I’ve noticed this annoying behaviour with some applications (specially games).
I usually leave some apps like Firestorm (a second life viewer) on my second monitor while I focus on something else on my main one and occasionally refocus the app when needed.
What I noticed is that when unfocused the app runs at 100+ fps but as soon as I refocus it it drops to 20-30 fps, my PC fans starts spinning like I just launched a program and the CPU spikes at around 70-80% for 5-6 seconds before getting back to its original framerate.
It seems like re-focusing the app makes it re-render everything as if you just opened it.
My CPU has no dedicated GPU, so I excluded the possibility of the apps running on it and causing the spike in performance. I also tried to tinker with the focus settings, especially the separate screen focus, but the behaviour remained. I’ve tried both X11 and Wayland and the same behaviour happens.
A similar behaviour happens with CS2, Half life 2 and Payday 3, they get very low FPS when unfocused (even if they aren’t minimized) but they snap back to their original framerate once focused again.
Does anyone have any idea? A friend of mine running AMD also experiences the same problem as me. I also tried with the power setting and get them to performance mode but to no avail.
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=456f37e4-3c23-4e90-a8b0-2b273d16ad90 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Mobo: ASUSTeK model: PRIME Z690M-PLUS D4 v: Rev 1.xx
UEFI: American Megatrends v: 2014 date: 10/14/2022
Info: model: 12th Gen Intel Core i5-12600KF bits: 64 type: MST AMCP
microcode: 0x37
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 875 min/max: 800/5000:3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 875 2: 875 3: 875 4: 875 5: 875 6: 875 7: 875
8: 875 9: 875 10: 875 11: 875 12: 875 13: 875 14: 875 15: 875 16: 875
bogomips: 117964
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
v: 565.57.01 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: none off: DP-1,DP-2,HDMI-A-1 empty: HDMI-A-2
bus-ID: 01:00.0 chip-ID: 10de:2484 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 5760x1080
display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: center res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 565.57.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
API: Vulkan v: 1.3.295 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 565.57.01
device-ID: 10de:2484 surfaces: xcb,xlib,wayland
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1d class-ID: 0200
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.75 TiB used: 1.1 TiB (40.1%)
ID-1: /dev/nvme0n1 maj-min: 259:5 model: GXF1TB size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: SN11590 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Lexar model: SSD NM710 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 9742 temp: 50.9 C scheme: MBR
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Lexar model: SSD NM710 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 9742 temp: 51.9 C scheme: GPT
used: 111.03 GiB (11.9%) fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:4
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A
Memory: total: 32 GiB available: 31.15 GiB used: 13.73 GiB (44.1%)
Processes: 504 Power: uptime: 9h 56m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
Packages: 2096 pm: pacman pkgs: 2076 libs: 586 tools: gnome-software,
octopi, pamac, paru, trizen pm: flatpak pkgs: 20 Compilers: clang: 18.1.8
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.36
System install date: 2024-11-18
Last full system update: 2024-11-30
