Hi there,
I've been having a weird issue with my kwin compositor on KDE for quite a while now. What happens is that any single window (usually the one that's in focus) will randomly freeze/stop repainting. everything else still works fine. I can still hear sound, do inputs, move the window and so on. it's really just the graphics that stop refreshing/repainting. i can force a repaint by changing focus or modifying the window in any way. moving another window on top of a frozen one will also reveal the area the window gets dragged over to still be repainting just fine. it's as if a single freeze frame is stuck in place of new ones.
I'm pretty sure it's a kwin issue, because when i go into the compositor settings and change any setting (which i presume reloads the compositor) it temporarily fixes the issue. I've tried individually changing all the compositor settings in case one of them was the cause, but to no avail.
I'm at my wits end as i can't even seem to reproduce the freeze in any reliable way. I'm hope I'm not the only one with this issue, because I've looked far and wide for a solution, however no matter which combination of keywords I used and without having any kind of error message to search for, I was unable to find one.
I might also add that it happens relatively infrequently, but in some situations, like during a game, it becomes a huge problem, especially during online play.
Kernel: 5.19.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a1822dc1-b702-4704-b47e-ce7a40ceb879 rw rootflags=subvol=@
nvidia-drm.modeset=1 ibt=off
Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3802
date: 03/15/2018
ID-1: hidpp_battery_7 charge: 93% condition: N/A volts: 4.1 min: N/A
model: Logitech Gaming Mouse G900 type: N/A serial: <filter> status: full
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 built: 2015 process: Intel 14nm family: 6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4200 min/max: 800/4200 scaling: driver: intel_pstate
governor: performance cores: 1: 4200 2: 4200 3: 4200 4: 4200 5: 4200
6: 4200 7: 4200 8: 4200 bogomips: 63999
vulnerable
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: ZOTAC driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: DP-1,DP-2,DP-3 empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1b80 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 7680x1440 s-dpi: 107 s-size: 1824x342mm (71.81x13.46")
s-diag: 1856mm (73.06")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: right
model: ViewSonic VX2705-2KP serial: <filter> built: 2021 res: 2560x1440
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: DP-2 note: disabled pos: primary,center model: Acer XB271HU
serial: <filter> built: 2016 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-3: DP-3 mapped: DP-4 note: disabled pos: primary,left
OpenGL: renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 1-9:4 chip-ID: 19f7:0003
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0300 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: RODE Microphones NT-USB type: USB
Sound Server-1: ALSA v: k5.19.8-zen1-1-zen running: yes
Device-2: Mellanox MT26448 [ConnectX EN 10GigE PCIe 2.0 5GT/s]
driver: mlx4_core v: 4.0-0 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max:
lanes: 8 port: N/A bus-ID: 05:00.0 chip-ID: 15b3:6750 class-ID: 0200
IF: enp5s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6.4.4:27 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 7 state: up address: <filter>
Local Storage: total: 2.96 TiB used: 635.64 GiB (21.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO
256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B0QBXX7
temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000BX500SSD1
type: SSD serial: <filter> rev: 030
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q
ID-1: / raw-size: 238.17 GiB size: 2.96 TiB (1273.32%) used: 635.64 GiB
(21.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 596 KiB
ID-3: /home raw-size: 238.17 GiB size: 2.96 TiB (1273.32%) used: 635.64
GiB (21.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 238.17 GiB size: 2.96 TiB (1273.32%) used: 635.64
ID-5: /var/tmp raw-size: 238.17 GiB size: 2.96 TiB (1273.32%) used: 635.64
ID-1: swap-1 type: zram size: 62.74 GiB used: 6.26 GiB (10.0%)
System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 56 C
Processes: 399 Uptime: 6h 23m wakeups: 129 Memory: 62.74 GiB used: 21.67
GiB (34.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1987 pm: pacman
pkgs: 1979 libs: 495 tools: octopi,paru pm: flatpak pkgs: 8 Shell: fish
v: 3.5.1 default: Zsh v: 5.9 running-in: yakuake inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-02-20
Last full system update: 2022-09-22 ↻
Failed units: shadow.service
