Weird issues with AMD GPU and Fresync Premium / Screen Flicker
Earlier this year I purchased the AOC 34" 21:9 1440p 144Hz VA monitor with Freesync Premium and for the last 5 months it has been working flawlessly.
I am running Garuda on Wayland, KDE6 and kernel 9.6 Mainline.
Over the last couple of weeks, I have very strong flicker on the top third of the screen but here were it is weird.
If I disable Freesync the flicker is still there but it is more white compare to the black under Freesync.
Setting the ARR to Always, it stops the strong flicker but there is still a very faint constant flicker covering the whole screen.
Setting the ARR back to Automatic it stops the flicker all together but then it will come back randomly in 1-2 hours or when I restart the PC.
When I am lowering the refresh to 120Hz it is less potent but still there, at 100Hz there are no issues what so ever.
Having plugged another 1440p 144Hz IPS monitor on my PC, I did not have that issue but it doesn’t have Freesync, and I concluded that it was the monitor and I did an RMA.
I have now purchased a Pixio 34" 21:9 1440p 144Hz (165Hz) VA Freesync Premium and I have the same exact problem.
I have tried reinstalling drivers, all packages and searched the internet and tried several solutions but none have worked (most of the issues are nVidia related and I cannot find many issues raised with an AMD setup).
Such as purchasing a VESA certified DP cable, ArchWiki instructions, removing OC profile from GPU and CPU, various settings on the monitor.
I also switched to x11 and I still get the same issues albeit slightly less potent.
To note, I have found a sticky plaster solution; when the PC startup from cold boot, if I change the ARR settings to Always, apply and then change back to Automatic/Never, there is no flicker however I have noticed that the PC will restart if I play a game for more than an hour (I crash to desktop). I have been using the same system and OS for the past 9+ months without issues and these only started in late May.
Any thoughts or guidance will be much appreciated.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_GB.UTF-8",
LC_NAME = "en_GB.UTF-8",
LC_MONETARY = "en_GB.UTF-8",
LC_PAPER = "en_GB.UTF-8",
LC_IDENTIFICATION = "en_GB.UTF-8",
LC_TELEPHONE = "en_GB.UTF-8",
LC_MEASUREMENT = "en_150.UTF-8",
LC_TIME = "en_GB.UTF-8",
LC_NUMERIC = "en_GB.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 6.10.0-rc3-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=94b372b7-b3bd-47cf-9e4c-762206fa87f1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
BIOS: American Megatrends v: 6063 date: 03/13/2023
ID-1: hidpp_battery_0 charge: 25% condition: N/A volts: 3.7 min: N/A
model: Logitech G703 Wired/Wireless Gaming Mouse type: N/A serial: <filter>
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3564 high: 4432 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3597 4: 3600 5: 3596 6: 3400 7: 3605 8: 3599 9: 3400 10: 3400 11: 3606
12: 3599 13: 3400 14: 3599 15: 4432 16: 3400 bogomips: 108859
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Sapphire NITRO+ driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, Writeback-1
bus-ID: 0d:00.0 chip-ID: 1002:73bf class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 res: 3440x1440 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.10.0-rc3-1-mainline) device-ID: 1002:73bf
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 24.1.1-arch1.1
device-ID: 1002:73bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab28
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 9-4:4 chip-ID: 1038:12ad class-ID: 0300
API: ALSA v: k6.10.0-rc3-1-mainline status: kernel-api with: aoss
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.87 TiB used: 1.16 TiB (30.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 28.9 C
scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM005 HD103SJ
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: 00E5 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 84.09 GiB (36.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
System Temperatures: cpu: 43.0 C mobo: 25.0 C gpu: amdgpu temp: 33.0 C
mem: 34.0 C
Fan Speeds (rpm): cpu: 526 case-1: 614 case-2: 0 case-3: 0 gpu: amdgpu
fan: 1047
Power: 12v: 12.16 5v: N/A 3.3v: N/A vbat: N/A gpu: amdgpu watts: 19.00
Memory: total: 32 GiB available: 31.25 GiB used: 4.79 GiB (15.3%)
Processes: 373 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2071 libs: 598
tools: octopi,paru,yay Compilers: clang: 17.0.6 gcc: 14.1.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date:     2023-12-27
Last full system update: 2024-06-14
Additional information.
I posted this on Arch forums as my thinking was that I use the mainline Kernel (I am still new and learning) and I was redirected here.
I got asked to check the following and I have also included my response.
*If I disable Freesync the flicker is still there*
So the subject is a falsehood, you’ve general signal issues.
*when the PC startup from cold boot, if I change the ARR settings to Always, apply and then change back to Automatic, there is no flicker however I have noticed that the PC will restart if I play a game for more than an hour (I crash to desktop). I have been using the same system and OS for the past 9+ months without issues and these only started in late May*
  1. power savings
  2. temperature
  3. cable (always)
My answers
  1. Everything is disabled as my PC and screen stay on until I manually shut it down.
  2. I have checked all temperatures and only a couple of months back I re-pasted all components (I do it every 2 years)
  3. I have tried 4 cables thus far and the one currently used is the VESA certified (8k at 60Hz) which is still causing issues.
