The Issue:
hi guys
since i changed the background of garuda dragonized when i boot the system the latte dock does this weird thing, (a glitch?) i cannot better explain it rather than linking a photo of it
then after a few seconds all seems to be normal again
i know its not a major issue but it still bothers me xD
the photos are taken with my phone, they are not screenshots.
What i tried:
I tried all these things without much success
- disabling latte on startup and running it manually
- trying delaying latte adding a splash screen on startup
- trying some dock settings
i hope someone could help me with this
thank u all in advance
output of inxi Faz:
inxi -Faz
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=500b18d4-94f8-4dca-b600-8c1bdeec5717 rw
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: HP product: HP Pavilion Power Laptop 15-cb0xx v: Type1ProductConfigId serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 836B v: 46.21 serial: <filter> UEFI: Insyde v: F.10 date: 07/28/2017
Battery: ID-1: BAT0 charge: 45.8 Wh (83.7%) condition: 54.7/54.7 Wh (100.0%) volts: 16.6 min: 15.4 model: HP Primary
type: Li-ion serial: N/A status: Unknown
CPU: Info: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44798
Speed: 800 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-4:2 chip-ID: 04f2:b5d6
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a171 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 4000 bus-ID: 04:00.0 chip-ID: 8086:095a
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 3000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:3 chip-ID: 8087:0a2a
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 1.03 TiB used: 9.92 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5KHA4102 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3T0 scheme: GPT
Partition: ID-1: / raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 9.91 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 9.91 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 9.91 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 118.99 GiB size: 118.99 GiB (100.00%) used: 9.91 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A
Info: Processes: 293 Uptime: 2m wakeups: 1 Memory: 15.51 GiB used: 2.6 GiB (16.8%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1378 lib: 335 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
