So for some context, my system was a sluggish and ocasionally, it would be very slow and unresponsive so i decided to follow this guide. After changing my kernel to LTS with this tutorial, i've noticed that when i move a window in kde it's like it becomes a gigant brush, i really don't know how to describe it better.
Kernel: 5.15.76-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=699e7526-cb49-4445-9710-7c7f4de28d89 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1
Type: Laptop System: Dell product: Inspiron 15-5578 v: N/A
Mobo: Dell model: 0P380W v: A00 serial: <superuser required> UEFI: Dell
v: 1.30.1 date: 05/27/2020
ID-1: BAT0 charge: 30.7 Wh (100.0%) condition: 30.7/39.9 Wh (76.9%)
volts: 12.9 min: 11.4 model: SMP DELL 35RH35C type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check gen: core 7 level: v3 note: check
built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 594 high: 603 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 577 2: 600 3: 599 4: 603
bogomips: 23199
Type: itlb_multihit status: KVM: Split huge pages
vulnerable
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0bda:58c6 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Monitor-1: eDP-1 model: AU Optronics 0x10ed built: 2016 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound API: ALSA v: k5.15.76-1-lts running: yes
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
bus-ID: 1-6:5 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 298.09 GiB used: 92.49 GiB (31.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK3275GSX
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1D scheme: GPT
ID-1: / raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 92.49 GiB
(31.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 624 KiB
ID-3: /home raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 92.49
GiB (31.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 92.49
ID-5: /var/tmp raw-size: 297.79 GiB size: 297.79 GiB (100.00%) used: 92.49
ID-1: swap-1 type: zram size: 7.63 GiB used: 950.5 MiB (12.2%)
System Temperatures: cpu: 49.0 C pch: 49.0 C mobo: 49.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 211 Uptime: 19m wakeups: 1 Memory: 7.63 GiB used: 3.83 GiB
(50.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1485 pm: pacman pkgs: 1474 libs: 366
tools: paru,yay pm: flatpak pkgs: 11 Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-04
Last full system update: 2022-11-02
Failed units: dev-binderfs.mount
