Weird and loud noise when trying to use 7.1 headphones
Hi, so I recently bought laptop and installed garuda. Now I’m trying to use my headphones(arctis nova pro wireless) using 7.1, but I don’t have this option in settings. When i click on 5.1 setting, suddenly the only thing i can hear is very loud noise that makes my ears ring. Can someone help me with this?
  Kernel: 6.17.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1 clocksource: tsc
    root=UUID=6464ed6e-0e98-44aa-aad7-af152e954b7a rw rootflags=subvol=@ quiet loglevel=3
  Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.18.0 wm: kwin_wayland vt: 1
  Type: Laptop System: Micro-Star product: Katana 15 HX B14WGK v: REV:1.0
  Mobo: Micro-Star model: MS-1587 v: REV:1.0 serial: <superuser required> part-nu: 1587.1
    uuid: <superuser required> UEFI: American Megatrends LLC. v: E1587IMS.102 date: 05/06/2025
  ID-1: BAT1 charge: 72.2 Wh (97.2%) condition: 74.3/72.4 Wh (102.6%) volts: 17.56 min: 15.48
    model: MSI BIF0_9 type: Li-ion serial: N/A charging: status: not charging cycles: N/A
  Info: model: Intel Core i7-14650HX bits: 64 type: MST AMCP arch: Raptor Lake gen: core 14
    level: v3 note: check built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
    stepping: 1 microcode: 0x12F
  Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2 st: 8 smt: enabled
    cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB L2: 24 MiB
    desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
  Speed (MHz): avg: 798 min/max: 800/5000:5200:3700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 798 2: 798 3: 798 4: 798 5: 798 6: 798 7: 798 8: 798 9: 798 10: 798
    11: 798 12: 798 13: 798 14: 798 15: 798 16: 798 17: 798 18: 798 19: 798 20: 798 21: 798 22: 798
    23: 798 24: 798 bogomips: 116121
  Device-1: Intel Raptor Lake-S UHD Graphics vendor: Micro-Star MSI driver: i915 v: kernel
    alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports: active: eDP-2 empty: none
    bus-ID: 0000:00:02.0 chip-ID: 8086:a78b class-ID: 0300
  Device-2: NVIDIA GB206M [GeForce RTX 5070 Max-Q / Mobile] vendor: Micro-Star MSI driver: nvidia
    v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of 2025-08)
    arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ ports: active: none
    empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:2d18 class-ID: 0300
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
    mode: 2.0 bus-ID: 1-3:3 chip-ID: 5986:217c class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 compositor: kwin_wayland
    driver: X: loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris
    gpu: i915 display-ID: 0
  Monitor-1: eDP-2 model: ChiMei InnoLux 0x154c built: 2020 res: mode: 2560x1440 hz: 165
    scale: 125% (1.25) to: 2048x1152 dpi: 189 gamma: 1.2 size: 344x193mm (13.54x7.6")
    diag: 394mm (15.5") ratio: 16:9 modes: 2560x1440
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: iris device: 3 drv: swrast gbm: drv: iris surfaceless: drv: nvidia wayland: drv: iris x11:
    drv: iris inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Graphics (RPL-S) device-ID: 8086:a78b memory: 30.31 GiB
    unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 15 device: 0 type: integrated-gpu name: Intel Graphics (RPL-S)
    driver: mesa intel v: 25.2.4-arch1.1 device-ID: 8086:a78b surfaces: N/A device: 1
    type: discrete-gpu name: NVIDIA GeForce RTX 5070 Laptop GPU driver: nvidia v: 580.95.05
    device-ID: 10de:2d18 surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
    driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM 20.1.8) device-ID: 10005:0000 surfaces: N/A
    gpu: corectrl, nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
  Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs, snd_sof_pci_intel_tgl, snd_hda_intel
    bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
  Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22eb
  Device-3: SteelSeries ApS Arctis Nova Pro Wireless driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:6 chip-ID: 1038:12e0
  API: ALSA v: k6.17.1-zen1-1-zen status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Raptor Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
    chip-ID: 8086:7a70 class-ID: 0280
  Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
    driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF-ID-1: ztyjkl5dbh state: unknown speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.4 lmp-v: 13 status:
    discoverable: no pairing: no class-ID: 6c010c
  Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel driver: vmd v: 0.6
    port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev: class-ID: 0104
  Local Storage: total: 1.82 TiB used: 803.3 GiB (43.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV3S2000G size: 1.82 TiB block-size:
    physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: P3BR0A27 temp: 46.9 C scheme: GPT
  ID-1: / raw-size: 433.2 GiB size: 433.2 GiB (100.00%) used: 69.49 GiB (16.0%) fs: btrfs
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 31.5 MiB (32.8%) fs: vfat
  ID-3: /home raw-size: 433.2 GiB size: 433.2 GiB (100.00%) used: 69.49 GiB (16.0%) fs: btrfs
  ID-4: /var/log raw-size: 433.2 GiB size: 433.2 GiB (100.00%) used: 69.49 GiB (16.0%) fs: btrfs
  ID-5: /var/tmp raw-size: 433.2 GiB size: 433.2 GiB (100.00%) used: 69.49 GiB (16.0%) fs: btrfs
  ID-1: swap-1 type: zram size: 31.04 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
  System Temperatures: cpu: 57.2 C mobo: N/A
  Memory: total: 32 GiB note: est. available: 31.04 GiB used: 6.58 GiB (21.2%)
  Processes: 558 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle avail: deep wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.35 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 258
  Packages: pm: pacman pkgs: 2648 libs: 599 tools: octopi,paru Compilers: clang: 20.1.8
    gcc: 15.2.1 Client: Unknown Client: electron inxi: 3.3.39
Garuda (2.11.1-1):
  System install date:     2025-09-12
  Garuda release:          250902
  Last full system update: 2025-10-09
23/24 checks run in 0.69 seconds ⌛
Powered by garuda-health 🦅
The arctis nova pro wireless has no support for true Surround Sound. Their Windows Software has “simulated” Surround Sound, which is not what this option you have found is. That option is for true Surround Sound.
Then, should I just use the stereo mode or there is some other option that would be able to simulate surround sound?
Stereo mode is going to be the most sound accurate even on Windows, usually.
I believe there are softwares that can do this simulation on Linux, but I’m no expert on this.
okay, thanks
