Webcamoid (Chaotic AUR) not capturing from camera anymore
Hey there,
once upon a time I installed Webcamoid to make photos with my notebook. This worked flawlessly but today, I wanted to make a photo and realized, it cannot capture images from the camera.
I also tested OBS and camera capture in the web browser, both work fine. But importantly, the camera capture works in both versions (Git and non-Git) of the AUR package. (The compilation duration is really a pain, inconvenient.)
When I ran the Chaotic AUR version from the console, it looks like it could be missing libraries or function names.
Garuda-inxi for you
Kernel: 6.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=11d26dd1-3904-490b-9e30-1b11c6731dc0 rw rootflags=subvol=@
sysrq_always_enabled=1
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Detachable System: SHIFT product: SHIFT13mi v: N/A
Mobo: SHIFT model: SHIFT13mi-pcb v: 06 serial: <superuser required>
part-nu: 0752454247011 uuid: <superuser required> UEFI: American Megatrends
LLC. v: 5.19 date: 01/13/2023
ID-1: BAT0 charge: 18.5 Wh (100%) condition: 18.5/53.7 Wh (34.5%)
volts: 13.2 min: 11.55 model: Intel SR 1 SR Real Battery type: Unknown
serial: <filter> charging: status: full cycles: N/A
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xBC
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1403 min/max: 400/4200 scaling: driver: intel_pstate
governor: performance cores: 1: 1403 2: 1403 3: 1403 4: 1403 5: 1403 6: 1403
7: 1403 8: 1403 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Orbbec 3D USB 2.0 Camera driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3
chip-ID: 2bc5:051e class-ID: 0102 serial: <filter>
Monitor-1: eDP-1 model: BOE Display 0x08dd built: 2019 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 166 gamma: 1.2
size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.5-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 30.35 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 6 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.2.5-arch1.2
device-ID: 8086:9a49 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.5-arch1.2 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: snd_hda_intel
chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.17.5-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 953.87 GiB used: 270.35 GiB (28.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM6A1 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.25D temp: 47.9 C
ID-1: / raw-size: 48.14 GiB size: 48.14 GiB (100.00%)
used: 26.26 GiB (54.5%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:6
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 660 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:5
ID-3: /home raw-size: 280.27 GiB size: 280.27 GiB (100.00%)
used: 244.09 GiB (87.1%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:7
ID-4: /var/log raw-size: 48.14 GiB size: 48.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.14 GiB size: 48.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 10.6 MiB (0.0%)
ID-2: swap-2 type: partition size: 3.91 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p9 maj-min: 259:8
System Temperatures: cpu: 54.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 8.24 GiB (26.5%)
Processes: 336 Power: uptime: 30m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2245 libs: 545 tools: pamac,paru Compilers:
clang: 21.1.4 gcc: 15.2.1 Shell: Bash v: 5.3.3 running-in: konsole
inxi: 3.3.39
Garuda (2.11.1-1):
System install date:     2023-04-30
Garuda release:          230319
Last full system update: 2025-10-29 ↻
Failed units:            nmb.service
The functional AUR version gives this command line output (without debug/info)
[2025-10-29 19:32:05.643, Webcamoid, 0x7fb414b7df80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libDesktopCapture_pipewire.so: /usr/lib/qt/plugins/avkys/libDesktopCapture_pipewire.so: undefined symbol: pw_stream_dequeue_buffer"
[2025-10-29 19:32:05.671, Webcamoid, 0x7fb414b7df80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoCapture_pipewire.so: /usr/lib/qt/plugins/avkys/libVideoCapture_pipewire.so: undefined symbol: pw_context_connect"
Chaotic AUR version gives me critical errors:
[2025-10-29 19:42:25.249, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libAudioEncoder_ffmpeg.so: libavcodec.so.61: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.256, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libDesktopCapture_ffmpeg.so: libavdevice.so.61: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.256, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libDesktopCapture_pipewire.so: /usr/lib/qt/plugins/avkys/libDesktopCapture_pipewire.so: undefined symbol: pw_stream_dequeue_buffer"
[2025-10-29 19:42:25.266, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libMultiSrc_ffmpeg.so: libavdevice.so.61: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.279, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoCapture_ffmpeg.so: libavcodec.so.61: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.282, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoCapture_pipewire.so: /usr/lib/qt/plugins/avkys/libVideoCapture_pipewire.so: undefined symbol: pw_context_connect"
[2025-10-29 19:42:25.286, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoEncoder_ffmpeg.so: libavcodec.so.61: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.286, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoEncoder_rav1e.so: librav1e.so.0.7: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.288, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoEncoder_vpx.so: libvpx.so.9: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.288, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoEncoder_x264.so: libx264.so.164: cannot open shared object file: No such file or directory"
[2025-10-29 19:42:25.288, Webcamoid, 0x7f5518294f80,  (0)] critical: "Cannot load library /usr/lib/qt/plugins/avkys/libVideoMuxer_ffmpeg.so: libavformat.so.61: cannot open shared object file: No such file or directory"
Maybe this is easy to fix. I thought, you like to know.
All the best
- Elmar
I just tried loading webcamoid on my system. It’s correctly identifying the webcam video source, however, nothing appears in the viewfinder, and nothing is saved when I attempt to save a photo. I don’t really use this application, so it doesn’t impact my workflow, but can confirm, something is up with this software.
