i am trying to bring new life into older system using garuda, its osx like so it was a natural choice for this imac i bought on craigslist just to experiment with running. i figured out everything and it runs like a dream however, i dont know how to get the webcam driver working...
im hoping to be able to keep these machines on the road in the future when mac drops support and pick them up cheap and resell them with linux at low cost to poor families
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=86b59923-6acc-4b84-bb71-ed317868a97d
rw [email protected] quiet
cryptdevice=UUID=18b18b7e-37a6-4005-a968-a02229079db3:luks-18b18b7e-37a6-4005-a968-a02229079db3
root=/dev/mapper/luks-18b18b7e-37a6-4005-a968-a02229079db3 splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
resume=/dev/mapper/luks-bd12e8c6-8fc1-4869-830b-e1e21a8c67d7 loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Apple product: iMac8,1 v: 1.0 serial: <filter> Chassis: type: 13
v: Mac-F226BEC8 serial: <filter>
Mobo: Apple model: Mac-F226BEC8 v: PVT serial: <filter> UEFI: Apple
v: IM81.88Z.00C1.B00.0802091538 date: 02/09/08
CPU: Info: Dual Core model: Intel Core2 Duo E8135 bits: 64 type: MCP arch: Penryn family: 6
model-id: 17 (23) stepping: 6 microcode: 60F cache: L2: 6 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 9569
Speed: 2392 MHz min/max: 800/2400 MHz Core speeds (MHz): 1: 2392 2: 2392
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD RV610/M74 [Mobility Radeon HD 2400 XT] vendor: Apple driver: radeon v: kernel
bus-ID: 01:00.0 chip-ID: 1002:94c8 class-ID: 0300
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 2-4:3 chip-ID: 05ac:8502
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: ati,radeon
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 444x277mm (17.5x10.9") s-diag: 523mm (20.6")
Monitor-1: LVDS res: 1680x1050 hz: 60 dpi: 99 size: 433x270mm (17.0x10.6") diag: 510mm (20.1")
OpenGL: renderer: AMD RV610 (DRM 2.50.0 / 5.14.16-zen1-1-zen LLVM 12.0.1) v: 3.3 Mesa 21.2.4
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 82801H HD Audio vendor: Apple driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:284b class-ID: 0403
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Network: Device-1: Broadcom BCM4321 802.11a/b/g/n vendor: Apple AirPort Extreme driver: wl v: kernel
modules: ssb bus-ID: 04:00.0 chip-ID: 14e4:4328 class-ID: 0280
IF: wls4 state: dormant mac: <filter>
Device-2: Marvell 88E8058 PCI-E Gigabit Ethernet driver: sky2 v: 1.30 port: 5000
bus-ID: 05:00.0 chip-ID: 11ab:436a class-ID: 0200
IF: ens5 state: down mac: <filter>
IF-ID-1: enp0s29f7u1 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Apple Bluetooth HCI type: USB driver: btusb v: 0.8 bus-ID: 3-1.1:3 chip-ID: 05ac:820f
Drives: Local Storage: total: 298.09 GiB used: 12.31 GiB (4.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDT721032SLA380 size: 298.09 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A36A
Partition: ID-1: / raw-size: 291.39 GiB size: 291.39 GiB (100.00%) used: 12.31 GiB (4.2%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-18b18b7e-37a6-4005-a968-a02229079db3
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 720 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 291.39 GiB size: 291.39 GiB (100.00%) used: 12.31 GiB (4.2%) fs: btrfs
ID-4: /var/log raw-size: 291.39 GiB size: 291.39 GiB (100.00%) used: 12.31 GiB (4.2%) fs: btrfs
ID-5: /var/tmp raw-size: 291.39 GiB size: 291.39 GiB (100.00%) used: 12.31 GiB (4.2%) fs: btrfs
ID-1: swap-1 type: zram size: 3.83 GiB used: 415.8 MiB (10.6%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 6.4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
maj-min: 254:1 mapped: luks-bd12e8c6-8fc1-4869-830b-e1e21a8c67d7
Sensors: System Temperatures: cpu: 66.0 C mobo: N/A gpu: radeon temp: 67.0 C
Fan Speeds (RPM): cpu: 1199
Info: Processes: 213 Uptime: 1h 2m wakeups: 0 Memory: 3.83 GiB used: 2.41 GiB (62.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1218 lib: 326
McFly: Importing shell history for the first time. This may take a minute or two...done. is making zoom work..
thanks in advance..
specs are as follows..
System: Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
McFly: Importing shell history for the first time. This may take a minute or two...done. ~~~
