Webcam Not Working with Intel Integrated Graphics
I’ve been having issues with the webcam in Zoom on my laptop; but now that I unplugged the TV and run on integrated graphics, the webcam does not work at all!
On NVIDIA setup (plugged in TV), webcam works but is very laggy (at least in Zoom).
On Intel integrated, the integrated webcam does not work at all.
I tried kernels linux-zen and linux. Updated, rebooted.
I open Kamoso, in the list of cameras, it says “SPCA2087 PC Camera (V4L2)”.
Yet, the image remains completely black.
What more can I do?
My inxi
Kernel: 6.5.9-arch2-1.1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 44.0 Wh (100.0%) condition: 44.0/58.8 Wh (74.8%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.104.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
empty: DP-1,HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Sunplus Innovation [] driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 1bcf:0b13
Monitor-1: eDP-1 model: AU Optronics 0x82ed built: 2018 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 23.2.1-arch1.2.1
device-ID: 8086:9bc4 memory: 15.09 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.2.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 535.104.05
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.5.9-arch2-1.1 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 1.7 TiB (53.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: WesteSystem:
status: full
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 508.55 GiB (27.5%)
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 508.55 GiB (27.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.45 GiB used: 21.5 MiB (0.1%)
System Temperatures: cpu: 39.0 C pch: 53.0 C mobo: N/A
Processes: 357 Uptime: 6m wakeups: 1 Memory: total: 16 GiB
available: 15.45 GiB used: 4.19 GiB (27.1%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11/12
clang: 16.0.6 Packages: pm: pacman pkgs: 2173 libs: 565
tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
Garuda (2.6.17-1):
System install date:     2021-11-24
Last full system update: 2023-10-26
Failed units:            systemd-networkd-wait-online.servicern Digital model: PC SN730
logical: 512 B speed: 31.6 Gb/s lanesSystem:
status: full
Garuda (2.6.17-1):
Failed units:            systemd-networkd-wait-online.service: 4 tech: SSD serial: <filter>
Garuda (2.6.17-1):
if I start Kamoso from the command-line, I get a bit of image before it crashes and gives me some debug info
Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
qrc:/qml/Config.qml:71: TypeError: Cannot read property 'filters' of null
error debugMessage: stream error: target not found
error: "../pipewire/src/gst/gstpipewiresrc.c(685): on_state_changed (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:/GstPipeWireSrc:HD User Facing (V4L2)"
Stop
Stop
(kamoso:10180): GLib-GObject-CRITICAL **: 13:42:43.727: g_object_notify: assertion 'G_IS_OBJECT (object)' failed
(kamoso:10180): GLib-GObject-CRITICAL **: 13:42:43.728: g_object_notify: assertion 'G_IS_OBJECT (object)' failed
Stop
20 -- exe=/usr/bin/kamoso
13 -- platform=xcb
11 -- display=:0
15 -- appname=kamoso
17 -- apppath=/usr/bin
10 -- signal=11
10 -- pid=10180
19 -- appversion=23.08.2
19 -- programname=Kamoso
31 -- bugaddress=submit@bugs.kde.org
KCrash: crashing... crashRecursionCounter = 2
KCrash: Application Name = kamoso path = /usr/bin pid = 10180
KCrash: Arguments: /usr/bin/kamoso
KCrash: Attempting to start /usr/lib/drkonqi
fish: Job 1, 'kamoso' has stopped
After playing with kernels and packages, the error magically went away and Kamoso is working again.
My observation right now: Zoom webcam in kernel linux lags when doing heavy CPU operations like installs, but otherwise runs pretty smooth like I would expect. Still some stuttering though… but seems better.
On kernel linux-zen or linux-xanmod, I get very heavy lag and stuttering and make it unusable.
So… webcam now working with internal graphics. I don’t know what the problem was.
