Hello guys. I have been having issues with my webcam and Garuda. When i try to use it with Kamoso, i get very low FPS and when i use it in Skype, FPS is fine but it takes a minute or two to become stable meaning it gets stuck then i have to disable and reenable the camera in skype.
As far as the solution goes, i have tried searching for answers in arch wiki, however nothing about lagginess or shutters is mentioned here.
https://wiki.archlinux.org/index.php/webcam_setup
I have also tried switching kernels with no avail. (linux-lts, linux-zen, linux-tkg-bmq)
Here is my system info:
System: Kernel: 5.10.27-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=2e5fa2c0-dcc6-46e1-81be-f773639c9d53
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <filter>
UEFI-[Legacy]: American Megatrends v: P4.30 date: 07/14/2020
CPU: Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check family: 17 (23) model-id: 18 (24) stepping: 1 microcode: 8108109
cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 28748
Speed: 2929 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz): 1: 2929 2: 2947
3: 2953 4: 2931
Graphics: Device-1: AMD Picasso driver: amdgpu v: kernel bus-ID: 06:00.0 chip-ID: 1002:15d8
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.10.27-1-lts LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: HDR webcam HDR webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-4:4
chip-ID: 1d6c:0103 class-ID: 0102
Sound Server-1: ALSA v: k5.10.27-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169
v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus-ID: 1-2:2 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 585 GiB used: 25.57 GiB (4.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-1EJ162 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: DEM7 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZYTY128HDHP-000L2 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 1L1Q scheme: MBR
Partition: ID-1: / raw-size: 119.24 GiB size: 119.24 GiB (100.00%) used: 25.57 GiB (21.4%) fs: btrfs
dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 119.24 GiB size: 119.24 GiB (100.00%) used: 25.57 GiB (21.4%) fs: btrfs
ID-3: /var/log raw-size: 119.24 GiB size: 119.24 GiB (100.00%) used: 25.57 GiB (21.4%)
fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-4: /var/tmp raw-size: 119.24 GiB size: 119.24 GiB (100.00%) used: 25.57 GiB (21.4%)
ID-1: swap-1 type: zram size: 3.4 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.4 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 3.4 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 3.4 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 45.0 C
Info: Processes: 226 Uptime: 10m wakeups: 0 Memory: 13.59 GiB used: 2.44 GiB (17.9%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1840 lib: 539
Shell: fish v: 3.2.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.03```
