I have an issue with my webcam on FireDragon. Might be a setting, im not sure, but would like to see if I can get some assistance.
I have a 1080p USB webcam hooked up to my laptop, and when I open up FireDragon and try to use the webcam on a site, it will initialize it and pull and image, but thats it. It will not continue with the feed, it pulls the initial image and stops. I tested this in Firefox ESR and it works just fine.
ixni posted below.
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a192f795-0935-4190-909b-7bed960ef2ed rw rootflags=subvol=@ quiet splash
resume=UUID=fe026fba-e046-400a-aead-15e86956c80e loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0 serial: <filter> Chassis:
type: 9 v: Mac-E43C1C25D4880AD6 serial: <filter>
Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1 serial: <filter>
UEFI: Apple v: MBP121.88Z.0177.B00.1806051659 date: 06/05/2018
Battery: ID-1: BAT0 charge: 39.1 Wh (54.4%) condition: 71.9/74.8 Wh (96.2%) volts: 11.3
min: 11.4 model: SMP bq20z451 type: Li-ion serial: N/A status: Discharging cycles: 47
CPU: Info: Dual Core model: Intel Core i5-5257U bits: 64 type: MT MCP arch: Broadwell
family: 6 model-id: 3D (61) stepping: 4 microcode: 2F cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21599
Speed: 2701 MHz min/max: 500/3100 MHz Core speeds (MHz): 1: 2701 2: 2701 3: 2700
4: 2701
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:162b class-ID: 0300
Device-2: Realtek FULL HD 1080P Webcam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:2 chip-ID: 0bda:58b0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (20.0x12.5")
s-diag: 598mm (23.5")
Monitor-1: eDP1 res: 1920x1200 hz: 60 dpi: 168 size: 290x180mm (11.4x7.1")
diag: 341mm (13.4")
OpenGL: renderer: Mesa Intel Iris Graphics 6100 (BDW GT3) v: 4.6 Mesa 21.1.6
direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A bus-ID: 02:00.0
chip-ID: 14e4:1570 class-ID: 0480
Device-4: Realtek FULL HD 1080P Webcam type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple driver: brcmfmac
v: kernel port: efa0 bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
Bluetooth: Device-1: Apple Bluetooth Host Controller type: USB driver: btusb,hid-generic,usbhid
bus-ID: 1-3:3 chip-ID: 05ac:8290 class-ID: fe01
Drives: Local Storage: total: 113 GiB used: 11.79 GiB (10.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0128G size: 113 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: PA0Q scheme: GPT
Partition: ID-1: / raw-size: 110.51 GiB size: 110.51 GiB (100.00%) used: 11.79 GiB (10.7%)
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%) used: 576 KiB (0.1%)
fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 110.51 GiB size: 110.51 GiB (100.00%) used: 11.79 GiB (10.7%)
ID-4: /var/log raw-size: 110.51 GiB size: 110.51 GiB (100.00%)
used: 11.79 GiB (10.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 110.51 GiB size: 110.51 GiB (100.00%)
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1
ID-2: swap-2 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
Sensors: System Temperatures: cpu: 71.5 C mobo: N/A
Info: Processes: 209 Uptime: 26m wakeups: 2 Memory: 7.67 GiB used: 3.39 GiB (44.1%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1253 lib: 311 Shell: fish v: 3.3.1 default: Bash v: 5.1.8
running-in: alacritty inxi: 3.3.06
If you include terminal outputs in your post please
use the proper output format in your post.
Using "~" 3 times above and "~" 3 times below the text block
will provide a readable, raw look
greetings
