Hi all,
I apologize if this post doesn't have all the required information, but I don't even know how to search for this. I've tried searching for "Web Terminal garbled" and similar search terms, but all of them have to do with terminal emulators. My specific issues is wherever I have to fire up a web terminal (Proxmox shells, Home Assistant SSH add-on, etc) the text is horribly garbled. Unreadable. I SSH into the box using an emulator whenever possible, but there are situations when a web terminal is all I've got. I can't post images as a new user, so here is a link to what I'm seeing. This is happening just in Firedragon, Chromium seems to work fine (which I just now figured out). I can use Chromium, but would prefer to stick with Firedragon if possible. I'm running Version 112.0.2 (64-bit).
Thanks so much, and sorry if anything is missing.
Here is the mandatory inxi output.
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=ff2cc117-24c7-4f76-b707-42f21c9cefb3 rw rootflags=subvol=@
resume=UUID=fef88398-0000-4eb8-81d6-102a5c40d0c3 loglevel=3 ibt=off
Type: Convertible System: LENOVO product: 81TC v: Lenovo Yoga C740-14IML
serial: <superuser required> Chassis: type: 31 v: Lenovo Yoga C740-14IML
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: BNCN38WW date: 07/15/2020
ID-1: BAT0 charge: 18.7 Wh (42.4%) condition: 44.1/51.0 Wh (86.5%)
volts: 7.2 min: 7.7 model: SMP L18M4PE0 type: Li-poly serial: <filter>
status: discharging cycles: 312
Device-1: wacom_battery_0 model: Wacom HID 51EC serial: N/A charge: 0%
rechargeable: yes status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF6
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3437 high: 3483 min/max: 400/4900 scaling:
driver: intel_pstate governor: performance cores: 1: 3463 2: 3427 3: 3483
4: 3425 5: 3425 6: 3429 7: 3426 8: 3425 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 13d3:56b2
class-ID: 0e02
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x284mm (19.92x11.18")
s-diag: 580mm (22.84")
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x8c41 built: 2018
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0401
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-2: virbr0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-3: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
Local Storage: total: 953.87 GiB used: 446.97 GiB (46.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170001 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 936.7 GiB size: 936.7 GiB (100.00%)
used: 446.97 GiB (47.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 936.7 GiB size: 936.7 GiB (100.00%)
ID-4: /var/log raw-size: 936.7 GiB size: 936.7 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.7 GiB size: 936.7 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.33 GiB used: 3.51 GiB (22.9%)
ID-2: swap-2 type: partition size: 16.87 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 95.0 C pch: 67.0 C mobo: N/A
Processes: 325 Uptime: 1d 1m wakeups: 54530 Memory: available: 15.33 GiB
used: 12.32 GiB (80.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2254
pm: pacman pkgs: 2222 libs: 586 tools: octopi,paru pm: flatpak pkgs: 32
Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.27
System install date: 2022-03-20
Last full system update: 2023-05-19 ↻
Failed units: shadow.service
