Hi,
My web contents are appearing dark. I don’t know why this is happening. I tried changing the themes, checked browser themes and made sure it is defaulted to ‘light’ theme but even then web content still appears dark. Some of the items are difficult to read or see. I couldn’t find any proper resolution around this which is why i am reaching out to you. Any help in this regard is greatly appreciated. I am sharing inxi details below:
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=fbbed090-28b1-4da3-9e06-f34a42d405c2 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop K5504VA_S5504VA
Mobo: ASUSTeK model: K5504VA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: K5504VA.301
date: 07/11/2023
ID-1: BAT0 charge: 69.3 Wh (100.0%) condition: 69.3/75.0 Wh (92.3%)
volts: 8.7 min: 8.0 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: full cycles: 23
Device-1: hidpp_battery_1 model: Logitech Wireless Keyboard
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4121
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 506 high: 1300 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 1300 4: 400
5: 400 6: 400 7: 916 8: 400 9: 400 10: 400 11: 400 12: 400 13: 751 14: 400
15: 766 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 119807
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
built: 2022+ ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:a7a0 class-ID: 0300
Device-2: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 3277:0022
class-ID: 0e02
Monitor-1: eDP-1 res: 1646x926 size: N/A modes: N/A
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 7.44 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 24.1.5-arch1.1
device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:51ca
class-ID: 0401
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 80.22 GiB (8.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN560 SDDPNQE-1T00-1102 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 74114000 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 375 GiB size: 375 GiB (100.00%) used: 80.16 GiB (21.4%)
fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
used: 66 MiB (25.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 375 GiB size: 375 GiB (100.00%)
used: 80.16 GiB (21.4%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 375 GiB size: 375 GiB (100.00%)
ID-5: /var/tmp raw-size: 375 GiB size: 375 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.25 GiB used: 1.23 GiB (8.1%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20
System Temperatures: cpu: 43.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.25 GiB used: 5.9 GiB (38.7%)
Processes: 406 Power: uptime: 2d 3h 1m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 7 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
Packages: 1603 pm: pacman pkgs: 1573 libs: 466 tools: octopi,paru,yay
pm: flatpak pkgs: 30 Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2023-10-31
Last full system update: 2024-08-04 ↻
I also installed wmctrl as i was going through certain solutions. I am sharing the output if that helps:
wmctrl -m
Class: N/A
PID: N/A
Window manager's "showing the desktop" mode: OFF
Regards,
Pavan
