So basically… your problems are:
- Glitchy desktop and cursor
- Something or other about Wine and FPS??
- An auto-loading torrent client???
This is going to get confusing fast, so I think this topic should only address the first problem raised in your post (as per the title of this topic really).
We’d appreciate it if you could go into more detail on the first issue, as I can assure you that Hyprland Wayland works and Xwayland is definitely a thing there, but I don’t know about Wayland for KDE or GNOME in Garuda. They probably work though, seeing as there’s a lot of people on the forums that use those spins.
Feel free to create new threads for your other problems mentioned. The second problem will belong in the unsupported software category, as Garuda doesn’t develop or manage Wine,or DXVK. Disabling auto-loading can also depend on your desktop environment, which the mandatory garuda-inxi will show.
You posted in the wrong category, so I moved it to the issues and assistance category for you. This category has a template which you need to follow before we continue any further.
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
