I really WANT to finally trash windows for good.
For my work I use only linux, fortunally.
For my private life I actually can’t migrate yet, because of must-use non wayland compatible apps, and would really like to use Garuda. It is 2-3 months I’m trying to solve my issues that doesn’t allow me to definitely trash windows. I have a second work and I really need to use these:
- XP-Pen tablet - Because of wayland it is impossible to make it works and have the pen actually writing in the screen it is replicating.
- Mouse and Keybaord sharing. I need other machines on my desk to be used with the same mouse and keyboard (and clipboard sharing is actually useful). Now I’m using Synergy, and it is not compatible with wayland.
For both I tried xwayland, and failed miserably.
This is the Garuda inxi:
Kernel: 6.9.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ffb10ea5-9e25-414f-b929-bca6809908c1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Micro-Star product: Vector GP68HX 13VI v: REV:1.0
Mobo: Micro-Star model: MS-15M1 v: REV:1.0 serial: <superuser required>
part-nu: 15M1.3 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E15M1IMS.308 date: 07/18/2023
ID-1: BAT1 charge: 83.3 Wh (98.0%) condition: 85.0/87.4 Wh (97.3%)
volts: 17.3 min: 15.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
ID-2: hidpp_battery_0 charge: 66% condition: N/A volts: 3.9 min: N/A
Info: model: 13th Gen Intel Core i9-13950HX bits: 64 type: MST AMCP
microcode: 0x123
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 1459 high: 5488 min/max: 800/5300:5500:4000 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
4: 801 5: 800 6: 1983 7: 800 8: 800 9: 2262 10: 800 11: 5488 12: 800
13: 1368 14: 800 15: 1181 16: 5300 17: 800 18: 800 19: 800 20: 798
21: 2301 22: 800 23: 800 24: 800 25: 800 26: 800 27: 800 28: 3397 29: 800
30: 2156 31: 3668 32: 800 bogomips: 154828
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Micro-Star MSI
driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
built: 2022+ ports: active: eDP-2 empty: DP-3, DP-4, HDMI-A-2, HDMI-A-3
bus-ID: 0000:00:02.0 chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA GN21-X11 [GeForce RTX 4090 Laptop GPU]
vendor: Micro-Star MSI driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,eDP-1 bus-ID: 0000:01:00.0 chip-ID: 10de:2717
Device-3: Bison HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:116f
Device-4: SHENZHEN AONI NexiGo N930AF FHD Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-8.2:8 chip-ID: 3443:930f class-ID: 0102
gpu: i915,nvidia d-rect: 1920x2280 display-ID: 0
Monitor-1: HDMI-A-1 pos: primary,top res: 1920x1080 size: N/A modes: N/A
Monitor-2: eDP-2 pos: bottom res: 1920x1200 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a788 memory: 30.52 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:a788 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 4090 Laptop GPU driver: nvidia
v: 550.78 device-ID: 10de:2717 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 17.0.6 256 bits) driver: mesa llvmpipe
v: 24.1.1-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50
class-ID: 0401
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22bb class-ID: 0403
Device-3: SHENZHEN AONI NexiGo N930AF FHD Webcam
Device-4: Logitech G635 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-8.3:9 chip-ID: 046d:0a89 class-ID: 0300
API: ALSA v: k6.9.2-zen1-1-zen status: kernel-api with: aoss
bus-ID: 0000:00:14.3 chip-ID: 8086:7a70 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: 4000 bus-ID: 0000:3a:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp58s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 4.58 TiB used: 92.6 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN560 SDDPNQE-1T00-1032 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 74104000 temp: 57.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Crucial model: CT4000P3PSSD8
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 59.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Lexar model: USB Flash Drive
size: 7.32 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1100
scheme: MBR
ID-1: / raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
used: 33.29 GiB (8.6%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
used: 92.4 MiB (9.0%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-4: /var/log raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-5: /var/tmp raw-size: 388.62 GiB size: 388.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.5 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 52.0 C mobo: N/A
Memory: total: 64 GiB note: est. available: 62.5 GiB used: 8.55 GiB (13.7%)
Processes: 587 Power: uptime: 50m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 24.96 GiB services: org_kde_powerdevil,
Packages: 2024 pm: pacman pkgs: 2016 libs: 583 tools: octopi,paru
pm: flatpak pkgs: 8 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-04-15
Last full system update: 2024-06-08
I use personal pc for (in order of priority)
- Teaching Online using Zoom meetings, OBS, Xournal, Synergy and XP-Pen tablet.
- Gaming (World of Warcraft) mostly, I’m waiting to test this part until I solve the above. Also steam, that is actually more compatible.
- Coding (rust, python, angular, C, assembler, etc etc) This is actually already working very good, and better than windows!
- Some AI projects.
I could find the best drawing tablet compatible with Linux and wayland, to solve this problem with some $$, but the sharing part is there.
I tried Barrier and input-lean, both not working. I tried a rust project ‘lan-mouse’ that is really promising, but for now I have more issues than solutions.
What would you suggest? Should I use X11 by default on all system? How many problem could arise from this choice? Should I use another Arch distro (yes, arch is the only fixed thing in my mind!)?
Thanks
