I was wondering if I can add/remove these shortcuts at the bottom panel, Can't seem to configure it till now.
Kernel: 6.2.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc
v: 12.2.1 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=2d25c876-8fec-479d-9df1-772e29dda581 rw
rootflags=subvol=@ quiet quiet splash
resume=UUID=c402cbac-b30c-4734-8805-ebcf7ae271b0
loglevel=3 ibt=off
Desktop: wayfire v: 0.7.5 info: waybar dm: greetd
Type: Laptop System: ASUSTeK product: X441NA v: 1.0
Mobo: ASUSTeK model: X441NA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X441NA.205 date: 11/18/2016
ID-1: BAT0 charge: 19.9 Wh (69.1%)
condition: 28.8/34.6 Wh (83.3%) volts: 10.8 min: 10.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging cycles: 388
Info: model: Intel Pentium N4200 bits: 64 type: MCP
arch: Goldmont level: v2 built: 2016 process: Intel 14nm
family: 6 model-id: 0x5C (92) stepping: 9 microcode: 0x48
Topology: cpus: 1x cores: 4 smt: <unsupported> cache:
L1: 224 KiB desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB
desc: 2x1024 KiB
Speed (MHz): avg: 1454 high: 1809 min/max: 800/2500
base/boost: 1100/2400 scaling: driver: intel_cpufreq
governor: schedutil volts: 1.2 V ext-clock: 100 MHz cores:
1: 1018 2: 1716 3: 1809 4: 1273 bogomips: 8755
Device-1: Intel Apollo Lake [HD Graphics 505] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-9 process: Intel 14n
built: 2015-16 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5a84 class-ID: 0300
Display: server: Xwayland v: 23.1.1 compositor: wayfire
v: 0.7.5 driver: gpu: i915 note: X driver n/a display-ID: :0
Monitor-1: eDP-1 model: AU Optronics 0x2d3c built: 2013
res: 1366x768 dpi: 112 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
API: EGL/GBM Message: No known Wayland EGL/GBM data
sources.
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900
Series Audio Cluster vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:5a98
API: ALSA v: k6.2.12-zen1-1-zen status: kernel-api
tools: N/A
Server-1: sndiod v: N/A status: off
tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 0.3.69 status: n/a (root, process)
with: 1: pipewire-pulse status: active 2: wireplumber
status: active 3: pipewire-alsa type: plugin 4: pw-jack
type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0
Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Lite-On driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0
chip-ID: 10ec:b723 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb
v: 0.8 bus-ID: 1-3:3 chip-ID: 0bda:b721 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up
address: <filter>
Local Storage: total: 465.76 GiB used: 9.07 GiB (1.9%)
SMART Message: Required tool smartctl not installed. Check
--recommends
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate
model: ST500LT012-1DG142 size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw-size: 457.41 GiB size: 457.41 GiB (100.00%)
used: 9.07 GiB (2.0%) fs: btrfs block-size: 4096 B
dev: /dev/sda2 maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 457.41 GiB size: 457.41 GiB (100.00%)
ID-4: /var/log raw-size: 457.41 GiB
size: 457.41 GiB (100.00%) used: 9.07 GiB (2.0%) fs: btrfs
block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 457.41 GiB
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 3.66 GiB used: 181 MiB (4.8%)
ID-2: swap-2 type: partition size: 8.06 GiB
used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2800
Processes: 208 Uptime: 29m wakeups: 1 Memory: 3.66 GiB
used: 1.62 GiB (44.1%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 12.2.1
clang: 15.0.7 Packages: pm: pacman pkgs: 1314 libs: 351
tools: pamac,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: kitty inxi: 3.3.26
System install date: 2023-04-22
Last full system update: 2023-04-23 ↻
Failed units: session-3.scope
