Wayfire is awesome, me not quite so much
I just installed Garuda Wayfire. It's freakin awesome. Everything works I just want to know where to go to find out how to add apps the panel and make dpi changes persist from one boot to another. would something like that be in the man pages or wiki?
  Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=ed4f4a09-f6fb-4503-8370-3a507e7f13fb rw [email protected]
    loglevel=3 ibt=off
  Desktop: wayfire v: 0.7.5 info: waybar vt: 1 dm: greetd
  Type: Laptop System: ASUSTeK product: ZenBook UX391FA v: 1.0
  Mobo: ASUSTeK model: UX391FA v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: UX391FA.304 date: 07/07/2020
  ID-1: BAT0 charge: 41.4 Wh (95.2%) condition: 43.5/50.0 Wh (87.1%)
    volts: 7.9 min: 7.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
    status: not charging
  Device-1: hid-0018:04F3:2772.0002-battery model: ELAN9008:00 04F3:2772
    serial: N/A charge: N/A status: N/A
  Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
    model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xF2
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1175 high: 2000 min/max: 400/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 900 2: 2000 3: 900 4: 900
    5: 2000 6: 900 7: 900 8: 900 bogomips: 31999
  Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: ASUSTeK
    ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:3ea0 class-ID: 0300
  Device-2: Sunplus Innovation 1080P Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.2:5
    chip-ID: 1bcf:28c4 class-ID: 0102 serial: <filter>
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 13d3:56b9
  Display: wayland server: Xwayland v: 23.1.1 compositor: wayfire v: 0.7.5
    driver: gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model-id: JDI 0x385a built: 2017 res: 3840x2160 dpi: 332
    gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
    modes: 3840x2160
  API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
    bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
  Device-3: RODE Microphones RØDE NT-USB Mini
    lanes: 1 mode: 1.1 bus-ID: 1-3.4:12 chip-ID: 19f7:0015 class-ID: 0300
  API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.3:5
  IF: enp55s0u2u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:10
  Local Storage: total: 4.56 TiB used: 7.4 GiB (0.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 27.9 C scheme: GPT
    model: WD40NDZW-11BGSS1 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 2007 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 model: USB DISK 3.0 size: 230.98 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
  ID-4: /dev/sdd maj-min: 8:48 vendor: Generic model: MassStorageClass
    size: 238.75 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: 1537 scheme: MBR
  ID-1: / raw-size: 234.34 GiB size: 234.34 GiB (100.00%) used: 7.4 GiB (3.2%)
    fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
    used: 703 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 234.34 GiB size: 234.34 GiB (100.00%)
    used: 7.4 GiB (3.2%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-4: /var/log raw-size: 234.34 GiB size: 234.34 GiB (100.00%)
  ID-5: /var/tmp raw-size: 234.34 GiB size: 234.34 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: N/A pch: 56.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 4100
  Processes: 254 Uptime: 37m wakeups: 611 Memory: available: 15.44 GiB
  used: 4.32 GiB (28.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1309
  libs: 389 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: gnome-terminal
  inxi: 3.3.27
  System install date:     2023-05-14
  Last full system update: 2023-05-15 ↻
One request per topic please. This makes the forum more usable for future readers.
I'm not a Wayfire user, but I think the panel can be configured here:
~/.config/wf-shell.ini
I assume this is where the config file lives. I would edit it in a text editor reverse engineering the entries and guessing what the entries might be for the apps I want to add, is this a correct assumption?
Sure. I like the cli tools, so I'd go for a:
micro ~/.config/wf-shell.ini
Search for the current shortcuts, change them, save, exit, log off and on.
Some additional info here:
This would be helpful if i try the wayfire
