Hi guys, did a full two days of researching the issue, but just cant get it to display active keyboard layout language. Ive read somewhere on reddit that apparently this was a known bug in 2023, but was supposed to be fixed december 2023, yet Im experiencing this issue.
Here is my waybar.config:
"layer": "top", // Waybar at top layer
"position": "top", // Waybar position (top|bottom|left|right)
"height": 35,
"width":1900,
"margin-top",
"margin": "0 0 0 0",
"spacing":0,
// Choose the order of the modules
"modules-left": ["custom/launcher", "hyprland/workspaces", "hyprland/window"],
"modules-right": [ "hyprland/language", "custom/pacman", "custom/network_traffic", "custom/weather","backlight", "custom/keyboard-layout", "temperature", "cpu", "memory", "battery", "pulseaudio", "network", "tray", "idle_inhibitor","clock","custom/power"],
// Modules configuration
"hyprland/language": {
"format": "{}",
"format-en": "Murica",
"format-ru": "Мяу =^~^=",
"keyboard-name": "at-translated-set-2-keyboard"
"hyprland/workspaces": {
"format": "{icon}",
"on-click": "activate",
"all-outputs": true,
"sort-by-number": true,
"format-icons": {
"1": "1",
"2": "2",
"3": "3",
"4": "4",
"5": "5",
"6": "6",
"7": "7",
"8": "8",
"9": "9",
"10": "10",
"focused": "",
"default": ""
"on-scroll-up": "hyprctl dispatch workspace e+1",
"on-scroll-down": "hyprctl dispatch workspace e-1",
"hyprland/window": {
"format": "{}",
"icon":true,
"icon-size" : 20
"idle_inhibitor": {
"format": "{icon}",
"format-icons": {
"activated": "",
"deactivated": ""
"tray": {
"icon-size": 20,
"spacing": 5
"clock": {
"tooltip-format": "<big>{:%A, %d.%B %Y }</big>\n<tt><small>{calendar}</small></tt>",
"format": " {:%a %d %b %I:%M %p}", //12 hour format
//"format": " {:%a %d %b %H:%M}", //24 hour format
"format-alt": " {:%d/%m/%Y %H:%M:%S}",
"timezones": [ "Europe/Moscow" ],
//"max-length": 200
"interval": 1,
"on-click": "~/.config/waybar/scripts/OCV",
"cpu": {
"format": "🖳{usage}%",
"on-click": "foot -e htop"
"memory": {
"format": "🖴 {: >3}%",
"temperature": {
"thermal-zone": 7, // Check with: # cat /sys/class/hwmon/hwmon*/temp1_input
"hwmon-path": "/sys/class/hwmon/hwmon7/temp1_input",
"critical-threshold": 80,
"format-critical": "{temperatureC}°C ",
"format": "{temperatureC}°C "
"backlight": {
// "device": "acpi_video1",
"format": "{icon} {percent: >3}%",
"format-icons": ["", ""],
"on-scroll-down": "brightnessctl -c backlight set 1%-",
"on-scroll-up": "brightnessctl -c backlight set +1%",
"on-click": "~/.config/waybar/scripts/backlight-hint.sh"
"battery": {
"states": {
// "good": 95,
"warning": 30,
"critical": 15
"format": "{icon} {capacity: >3}%",
"format-icons": ["", "", "", "", ""]
// "format-good": "", // An empty format will hide the module
// "format-full": "",
//"format-icons": ["", "", "", "", "", "", "", "", "", ""]
//"format": "‫{icon}‬ {capacity}%",
//"format-icons": ["ﱉ","ﱊ","ﱌ","ﱍ","ﱋ"]
"network": {
//"interface": "wlp0s20f3", // (Optional) To force the use of this interface "format-wifi": " {essid}",
"format": "⚠Disabled",
"format-wifi": " ",
"format-ethernet": "{ifname}: {ipaddr}/{cidr}",
"format-linked": "{ifname} (No IP)",
"format-disconnected": "⚠Disabled",
"format-alt": "{ifname}: {ipaddr}/{cidr}",
"family": "ipv4",
"tooltip-format-wifi": " {ifname} @ {essid}\nIP: {ipaddr}\nStrength: {signalStrength}%\nFreq: {frequency}MHz\nUp: {bandwidthUpBits} Down: {bandwidthDownBits}",
"tooltip-format-ethernet": " {ifname}\nIP: {ipaddr}\n up: {bandwidthUpBits} down: {bandwidthDownBits}",
//"min-length": 2,
//"max-length": 2,
"on-click": "nm-connection-editor"
"custom/pacman": {
"format": " {}",
"interval": 7200, // every two hours
"exec": "checkupdates | wc -l", // # of updates
//"exec": "i=$(checkupdates); echo \"$i\" |wc -l; echo \"$i\" |column -t |tr '\n' '\r'", // # of updates and tooltip details
"exec-if": "exit 0", // always run; consider advanced run conditions
"on-click": "foot -e update", // update system
"signal": 8
"custom/power": {
"format":"⏻",
"on-click": "nwgbar",
"tooltip": false,
"custom/keyboard-layout": {
"format": " Cheat", // Icon: keyboard
"on-click": "~/.config/waybar/scripts/keyhint.sh",
"custom/launcher": {
"format":"",
"on-click": "exec nwg-drawer -c 7 -is 70 -spacing 23",
"tooltip": false,
"custom/network_traffic": {
"exec": "~/.config/waybar/scripts/network_traffic.sh",
"return-type": "json",
"format-ethernet": "{icon} {ifname} ⇣{bandwidthDownBytes} ⇡{bandwidthUpBytes}", // optional
"pulseaudio": {
"scroll-step": 3, // %, can be a float
"format": "{icon} {volume}% {format_source}",
"format-bluetooth": "{volume}% {icon} {format_source}",
"format-bluetooth-muted": " {icon} {format_source}",
"format-muted": " {format_source}",
//"format-source": "{volume}% ",
//"format-source-muted": "",
"format-source": "",
"format-icons": {
"headphone": "",
"hands-free": "",
"headset": "",
"phone": "",
"portable": "",
"car": "",
"default": ["", "", ""]
"on-click": "pavucontrol",
"on-click-right": "pactl set-source-mute @DEFAULT_SOURCE@ toggle"
// https://github.com/chubin/wttr.in
"custom/weather": {
"exec": "curl 'https://wttr.in/krasnodar?format=2'",
"interval": 900,
"on-click": "yad --html --uri='https://wttr.in/krasnodar' --center --fixed --width=1000 --height=680 --timeout=60 --timeout-indicator=right"
And here is the waybar style.css:
* Waybar configuration
* Configuration reference: https://github.com/Alexays/Waybar/wiki/Configuration
* Keyframes
Polar Night
nord0 #2e3440
nord1 #3b4252
nord2 #434c5e
nord3 #4c566a
Snow Storm
nord4 #d8dee9
nord5 #e5e9f0
nord6 #eceff4
Frost
nord7 #8fbcbb
nord8 #88c0d0
nord9 #81a1c1
nord10 #5e81ac
Aurora
nord11 #bf616a
nord12 #d08770
nord13 #ebcb8b
nord14 #a3be8c
nord15 #b48ead
* Base styles
/* Reset all styles */
color: #eceff4;
border: 0;
border-radius: 0;
padding: 0 0;
font-family:Symbols Nerd Font Mono;
font-size: 15px;
margin-right: 5px;
margin-left: 5px;
padding-bottom:2px;
window#waybar {
background:rgba (0, 0, 0, 0.5);
border-radius: 20px 20px 20px 20px;
#workspaces button {
padding: 2px 0px;
border-bottom: 2px;
color: #eceff4;
border-color: #d8dee9;
border-style: solid;
margin-top:2px;
#workspaces button.active {
border-color: #81a1c1;
#language, #clock, #battery, #cpu, #memory,#idle_inhibitor, #temperature,#custom-keyboard-layout, #backlight, #network, #pulseaudio, #tray, #window,#custom-launcher,#custom-power,#custom-pacman ,#custom-network_traffic,#custom-weather{
padding: 0 3px;
border-bottom: 2px;
* Module styles
#language {
color: #8fbcbb;
#clock {
color:#a3be8c;
#backlight {
color: #ebcb8b;
#battery {
color: #d8dee9;
#battery.charging {
color: #81a1c1;
@keyframes blink {
to {
color: #4c566a;
background-color: #eceff4;
#battery.critical:not(.charging) {
background: #bf616a;
color: #eceff4;
animation-name: blink;
animation-duration: 0.5s;
animation-timing-function: linear;
animation-iteration-count: infinite;
animation-direction: alternate;
#cpu {
color:#a3be8c ;
#memory {
color: #d3869b;
#network.disabled {
color:#bf616a;
#network{
color:#a3be8c;
#network.disconnected {
color: #bf616a;
#pulseaudio {
color: #b48ead;
#pulseaudio.muted {
color: #3b4252;
#temperature {
color: #8fbcbb;
#temperature.critical {
color: #bf616a;
#idle_inhibitor {
color: #ebcb8b;
#tray {
#custom-launcher,#custom-power{
border-style: hidden;
margin-top:2px;
#window{
margin-top:1px;
#custom-keyboard-layout{
color:#d08770;
#custom-network_traffic{
color:#d08770;
Garuda-inxi:
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bac633bb-1d4c-47f7-ab8a-9b019659246a rw rootflags=subvol=@
Desktop: Hyprland v: 0.37.1-48-g059e85ae with: waybar tools:
avail: swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: HONOR product: FRI-FXX v: M2010
Mobo: HONOR model: FRI-FXX-PCB v: M2010 serial: <superuser required>
part-nu: C233 uuid: <superuser required> UEFI: HONOR v: 1.11
date: 03/23/2023
ID-1: BAT0 charge: 59.4 Wh (99.7%) condition: 59.6/59.7 Wh (99.9%)
volts: 13.1 min: 11.6 model: DESAY AP16L5J type: Li-ion serial: <filter>
status: not charging cycles: 5
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x432
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB
L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 525 high: 918 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 800 4: 400
5: 691 6: 918 7: 400 8: 698 9: 400 10: 400 11: 400 12: 400 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a3 class-ID: 0300
Device-2: ShineOptics HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 3277:0045
compositor: Hyprland v: 0.37.1-48-g059e85ae driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x0b8f built: 2022 res: 1920x1200
hz: 60 dpi: 161 gamma: 1.2 scale: 1 size: 302x188mm (11.89x7.4")
diag: 356mm (14") ratio: 16:10 modes: 1920x1200
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 24.0.3-arch1.2
device-ID: 8086:46a3 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: veth2e8c753 state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0026
Local Storage: total: 476.94 GiB used: 30.08 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Hynix model: YMTC PC300-512GB-B
lanes: 4 tech: SSD serial: <filter> fw-rev: YM0500C6 temp: 35.9 C
ID-1: / raw-size: 99.55 GiB size: 99.55 GiB (100.00%)
used: 30.08 GiB (30.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 99.55 GiB size: 99.55 GiB (100.00%)
ID-4: /var/log raw-size: 99.55 GiB size: 99.55 GiB (100.00%)
ID-5: /var/tmp raw-size: 99.55 GiB size: 99.55 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.33 GiB used: 3.79 GiB (24.7%)
Processes: 291 Power: uptime: 6h 32m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 2 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.12 GiB services: upowerd
Packages: pm: pacman pkgs: 1319 libs: 409 tools: pacseek,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: foot
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-22
Last full system update: 2024-03-24
As far as I can see, there is no error in the syntax, yet tall im getting is a “…” looking icon on the waybar.
Thanks for your help :З
