Hello,
today after I updated the waybar I found that it is now showing icons in the waybar of what ever app I have focused on like this :
But some are getting too much big than I expected, like (icon of garuda assistant ) :
I have searched on internet, there were some plenty of people who faced that issue but they were with their custom icons and these issues were year old
I just want to ask that is there any way to fix the icon size ? (please don't tell me about custom icon size can be fixed in this way or that way as I am not talking about that )
please help me to get rid of this annoying problem ...
thanks in advance ![]()
garuda-inxi :
╭─ankur@ankur in ~
╰─λ garuda-inxi
Kernel: 5.16.11-1-cacule x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=3d8862a3-cc90-4161-81ad-195e8064062c rw rootflags=subvol=@
loglevel=3 quiet splash systemd.unified_cgroup_hierarchy=1
sysrq_always_enabled=1
Desktop: sway 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Laptop System: Dell product: Inspiron 7570 v: N/A
Mobo: Dell model: 06K08K v: A00 serial: <superuser required> UEFI: Dell
v: 1.16.0 date: 02/17/2020
ID-1: BAT0 charge: 21.2 Wh (100.0%) condition: 21.2/42.0 Wh (50.5%)
volts: 12.5 min: 11.4 model: Samsung SDI DELL CYMGM79 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: Discharging
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1796 high: 1801 min/max: 400/4000 scaling:
driver: intel_pstate governor: performance cores: 1: 1800 2: 1801 3: 1774
4: 1800 5: 1800 6: 1800 7: 1800 8: 1800 bogomips: 32026
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:28c1 class-ID: 0e02
Display: wayland server: Xwayland v: 22.1.0 compositor: sway v: 1.7
driver: gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: BOE Display built: 2016 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.5x7.6")
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.16.11-1-cacule running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.14 TiB used: 48.97 GiB (4.2%)
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: L003 scheme: GPT
used: 48.97 GiB (5.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.51 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 45.5 C mobo: 44.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Processes: 260 Uptime: 47m wakeups: 4 Memory: 7.51 GiB
used: 2.64 GiB (35.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1545 lib: 472 Shell: fish
v: 3.3.1 running-in: alacritty inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-04
Last full system update: 2022-03-07
Failed units: systemd-guest-user.service
╭─ankur@ankur in ~ took 1s
╰─λ
