[email protected] in ~ as š§ took 30s
ā°āĪ» garuda-inxi
Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=8b137375-4cdd-49aa-9d1d-4a56bde51ee9 rw [email protected]
loglevel=3 ibt=off
Mobo: ASUSTeK model: PRIME Z490-A v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 2601 date: 05/17/2022
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1362 high: 3800 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 3800 3: 3800
4: 800 5: 800 6: 800 7: 800 8: 801 9: 801 10: 800 11: 3800 12: 802 13: 800
14: 800 15: 800 16: 800 bogomips: 121596
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 52.0 C
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: AOC Q32G1WG4 serial: <filter>
built: 2019 res: 2560x1440 dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon RX 580 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.1.9-zen1-2-zen) direct-render: Yes
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.18 TiB used: 8.35 GiB (0.3%)
model: WDS250G2B0C-00PXH0 size: 232.89 GiB block-size: physical: 512 B
rev: 211070WD temp: 34.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
rev: 2B2QEXM7 temp: 42.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD130 size: 2.73 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: ACF0 scheme: GPT
used: 8.35 GiB (3.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1183
Processes: 326 Uptime: 5m wakeups: 0 Memory: 31.25 GiB used: 2.61 GiB (8.3%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1316 libs: 332
tools: gnome-software,octopi,pamac,paru Shell: fish v: 3.6.0
running-in: konsole inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-02-08
Last full system update: 2023-02-08
warning: inxi: local (3.3.25.1-1) is newer than community (3.3.24.1-4)
warning: python-cryptography: local (39.0.1-1) is newer than extra (39.0.0-1)
warning: python-setuptools: local (1:67.2.0-1) is newer than extra (1:67.1.0-1)
warning: python-trove-classifiers: local (2023.2.8-1) is newer than extra (2023.1.20-1)
there is nothing to do
Is there something to do here? thank you
