how to fix this??
Maybe check if this favourite filter can be also your issue:
Check also for open issues there, and maybe, just in case, you have all the prerequisites:
Last but not least: your garuda-inxi is missing, and it was missing in all your previous topics.
I know it may seem unnecessary at times, but this can help also in those cases, to see that at least the system is up-to-date.
Most importantly, adding it shows respect for the rules (template).
If the above is not helping, I leave it to someone else, since I'm not even a steam user, but please make sure you get used to using garuda-inxi, otherwise topics might (and should) be moved to preconditions failed.
Judging from the location you set to source wallpapers from, you apparently missed reading the manual:
- Wallpaper Engine installed on Steam
- Subscribe to some wallpapers on the Workshop
- Select the steamlibrary folder on the Wallpapers tab of this plugin
The steamlibrary which contains the steamapps folder
Wallpaper Engine needs to be installed in this steamlibrary
