When I set the wallpaper engine de scence type as wallpaper, the background is only black, how can I fix it?
Kernel: 5.15.75-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=0b228500-941e-42be-8895-b8d0589c5140
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MONSTER product: ABRA A7 V12.5 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: MONSTER model: ABRA A7 V12.5 serial: <superuser required> UEFI: INSYDE v: 1.07.10TFB24
date: 12/06/2021
ID-1: BAT0 charge: 45.3 Wh (100.0%) condition: 45.3/47.2 Wh (96.0%) volts: 16.4 min: 14.4
model: Notebook BAT type: Li-ion serial: <filter> status: full
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
level: v4 note: check built: 2020 process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
microcode: 0x40
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 480 KiB desc: d-6x48
KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3717 high: 4162 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 3357 2: 3593 3: 4162 4: 3878 5: 3994 6: 4078 7: 3869 8: 3710
9: 3504 10: 3646 11: 3486 12: 3329 bogomips: 64512
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: SW
sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: CLEVO/KAPOK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-10)
arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
Device-3: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:3 chip-ID: 04f2:b729
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0a15 built: 2021 res: 1920x1080 hz: 144 dpi: 128
gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound API: ALSA v: k5.15.75-1-lts running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iw
lwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0026
Local Storage: total: 465.76 GiB used: 70.72 GiB (15.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
rev: P2CR048 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 70.68 GiB (29.6%) fs: btrfs
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 43.8 MiB (45.7%) fs: vfat
ID-3: /home raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 70.68 GiB (29.6%) fs: btrfs
ID-4: /var/log raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 70.68 GiB (29.6%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/tmp raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 70.68 GiB (29.6%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 1.69 GiB (11.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 438 Uptime: 27m wakeups: 1 Memory: 15.41 GiB used: 12.59 GiB (81.7%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1712
libs: 406 tools: gnome-software,octopi,pamac,paru Client: shell wrapper v: 5.1.16-release
inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-09-08
Last full system update: 2022-10-29
Failed units: dev-binderfs.mount systemd-networkd-wait-online.service
PLASMASHELL REPLACE ->
kf.plasma.quick: Applet preload policy set to 1
qml: JSON.parse: Parse error
qml: load backend: backend/Scene.qml
INFO main looper started
INFO render looper started
INFO source: /home/muktesit/.local/share/Steam/steamapps/workshop/content/431960/1552273169/scene.json
file:///home/muktesit/.local/share/plasma/wallpapers/com.github.casout.wallpaperEngineKde/contents/ui/backend/
Scene.qml:37:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this s
yntax instead: function onFoo(<arguments>) { ... }
qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
INFO gl: OpenGL version 4.6 loaded
INFO gl: OpenGL vendor string: Intel
INFO gl: external tex using optimal tiling
INFO set swapchain image size: 1920x1080
org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
QProcess: Destroyed while process ("/bin/sh") is still running.
qml: ----python helper connected----
INFO vulkan device: Intel(R) UHD Graphics (TGL GT1)
INFO new buffer block(0x7f4838398f40), size: 2097152, index: 0 / 1
INFO new buffer block(0x7f4838399030), size: 2097152, index: 0 / 1
INFO loading scene: /home/muktesit/.local/share/Steam/steamapps/workshop/content/431960/1552273169/scene.json
INFO muted, not init sound device
ERROR PhysicalFs.h:46 "/home/muktesit/.local/share/Steam/steamapps/common/wallpaper_engine/assets" not exists
ERROR SceneWallpaper.cpp:389 Mount assets dir failed
qml: QQuickGridView_QML_225(0x561d0fc3def0)```
