So I have flashed the latest ISO of Garuda Linux , v240428 Dragonized Non-Gaming on a 32gb SanDisk USB drive using Balena Etcher which was downloaded through official torrent available on Garuda’s download page.
Booted up through rEFInd whilst secure boot is set to off and sata mode to AHCI
Upon booting, I connected to my wifi mobile hotspot and when asked for encryption key by KDE Wallet, selected Classic Blowfish Encrypted File after which I filled in a blank password and clicked ok.
Started Calamares through setup assistant, kept stuck at Waiting for modules and reached 372 seconds.
Closed and started again.
Disabled IPV6 , and reconnected.
Tried USB tethering.
All of this: no luck.
Rebooted, due to sheer frustration, closed the window which asks for wallet encryption upon connecting to wifi, and well after 2-3 mins , it worked !
To test further, tried closing the installer and opened it again, no luck.
Rebooted, entered blank encryption password and waited and well it worked !
Closed again and re-opened.
Rebooted , entered blank password and before starting installer, changed wifi security settings to not encrypted in settings.
Closed , re-opened.
Again three of these steps, no luck.
Ran
sudo killall calamares
Ran installer again and it worked !
This was quite annoying.
As per my observations, after being infinitely stuck , if you close the installer within the installer, it’s instance doesn’t get closed and it keeps running in the background, due to which the setup assistant doesn’t appear despite the intended behaviour.
In one instance after closing and reopening Calamares several times, I checked with pidof
and found several instances of Calamares running.
TLDR
All instances show same logs with them
looping around same module: partition
and get
hung on closing with the same logs. Calamares gets stuck and has the instance running because a job for grub-mount
and os-prober
hangs and keeps running in the background. Logs below:
TLDR END
Optional to read as too long so idk
Seems the stucking and working of Calamares is really random and not setting wallet encryption really helps sometimes. Also Calamares doesn’t fully close most of the times.
Also to add, installation takes way longer than my previous experience, around 20-25 mins I have been sitting at the desk and well its kind meh ?, idk if it’s normal to take this long and if it’s related.
Logs:
Using sudo -E calamares -d
1.Calamares Logs after a fresh boot into the iso where the installer worked fine the first time but was closed(successfully bringing up the setup assistant) and re-opened:
21:56:23 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
.. Required settings.conf key hide-back-and-next-during-exec is missing.
21:56:23 [6]: void Logger::setupLogfile()
Using log file: "/home/garuda/.cache/calamares/session.log"
21:56:23 [6]: void CalamaresApplication::init()
Calamares version: 3.3.6
.. Using Qt version: 6.7.0
.. Build type: Release
.. Using PyBind11
.. Using settings: "/etc/calamares/settings.conf"
.. Using log file: "/home/garuda/.cache/calamares/session.log"
.. Languages: QList("ar", "as", "ast", "az", "az_AZ", "be", "bg", "bn", "ca", "ca@valencia", "cs_CZ", "da", "de", "el", "en", "en_GB", "eo", "es", "es_AR", "es_MX", "et", "eu", "fa", "fi_FI", "fr", "fur", "gl", "he","hi", "hr", "hu", "id", "is", "it_IT", "ja", "ka", "ko", "lt", "ml", "mr", "nb", "nl", "oc", "pl", "pt_BR", "pt_PT", "ro", "ru", "si", "sk", "sl", "sq", "sr", "sr@latin", "sv", "tg", "th", "tr_TR", "uk", "vi", "zh_CN", "zh_TW")
21:56:23 [6]: bool Calamares::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
21:56:23 [6]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
Using Calamares branding file at "/usr/share/calamares/branding/garuda/branding.desc"
21:56:23 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Branding::PanelFlavor&, Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
21:56:23 [2]: Calamares::Branding::Branding(const QString&, QObject*, qreal)
WARNING: the branding component "/usr/share/calamares/branding/garuda" does not ship translations.
Loaded branding component "garuda"
.. No translation for "tz_" "C" using default (en)
.. No translation for "calamares_" "C" using default (en)
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
21:56:23 [6]: void Calamares::ModuleManager::doInit()
Found 52 modules
21:56:23 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
21:56:23 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1920, 1048) minimum size QSize(1024, 520)
.. Proposed window size: 1024 664
21:56:23 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/garuda" does not ship stylesheet.qss.
STARTUP: CalamaresWindow created; loadModules started
21:56:23 [6]: void Config::initLanguages()
Trying to match locale "C"
Trying to match locale QLocale(C, Default, Default)
.. Trying to match approximate locale QLocale::C
.. Trying to match English (US)
21:56:23 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale "en"
.. Loaded QRC translation "tz_" "en"
.. Loaded QRC translation "calamares_" "en"
21:56:23 [2]: WARNING (Qt): OpenType support missing for "Fira Sans", script 12
21:56:23 [2]: WARNING (Qt): OpenType support missing for "Fira Sans", script 11
21:56:23 [2]: WARNING (Qt): OpenType support missing for "Fira Sans", script 19
21:56:23 [2]: WARNING (Qt): OpenType support missing for "Fira Sans", script 20
21:56:23 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
21:56:23 [6]: QStringList loadLocales(const QString&)
Loading locales from "/usr/share/i18n/SUPPORTED"
.. Read 498 lines
.. After filtering 323 lines
ViewModule "locale@locale" loading complete.
21:56:23 [2]: void Calamares::Module::loadConfigurationFile(const QString&)
WARNING: No config file for "keyboard" found anywhere at
"/home/garuda/src/modules/keyboard/keyboard.conf"
"/etc/calamares/modules/keyboard.conf"
"/usr/share/calamares/modules/keyboard.conf"
21:56:23 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 186 keyboard models
21:56:23 [6]: KeyboardGroupsSwitchersModel::KeyboardGroupsSwitchersModel(QObject*)
Loaded 40 keyboard groups
21:56:23 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now total= 0 selected= -1
Groups now total= 40 selected= -1
.. Loaded QRC translation "kb_" "en"
21:56:23 [6]: void Config::getCurrentKeyboardLayoutXkb(QString&, QString&, QString&)
QList("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
21:56:24 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "keyboard@keyboard" loading complete.
21:56:24 [6]: Calamares::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
21:56:24 [6]: DEBUG (Qt): Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x62dbc4bde900 "pmsfdiskbackendplugin" "1"
21:56:24 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
21:56:24 [2]: bool addPasswordCheck(const QString&, const QVariant&, PasswordCheckList&)
WARNING: nonempty check is ignored; use minLength: 1
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
21:56:24 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
21:56:24 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"qrc:/qt/qml"
"/usr/lib/qt6/qml"
21:56:24 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
21:56:24 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
21:56:24 [2]: void Calamares::Module::loadConfigurationFile(const QString&)
WARNING: No config file for "fstab" found anywhere at
"/home/garuda/src/modules/fstab/fstab.conf"
"/etc/calamares/modules/fstab.conf"
"/usr/share/calamares/modules/fstab.conf"
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
WARNING: No config file for "luksbootkeyfile" found anywhere at
"/home/garuda/src/modules/luksbootkeyfile/luksbootkeyfile.conf"
"/etc/calamares/modules/luksbootkeyfile.conf"
"/usr/share/calamares/modules/luksbootkeyfile.conf"
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
CppJobModule "dracutlukscfg@dracutlukscfg" loading complete.
Module "users@users" already loaded.
WARNING: No config file for "grubcfg" found anywhere at
"/home/garuda/src/modules/grubcfg/grubcfg.conf"
"/etc/calamares/modules/grubcfg.conf"
"/usr/share/calamares/modules/grubcfg.conf"
WARNING: No config file for "postcfg" found anywhere at
"/home/garuda/src/modules/postcfg/postcfg.conf"
"/etc/calamares/modules/postcfg.conf"
"/usr/share/calamares/modules/postcfg.conf"
WARNING: No config file for "umount" found anywhere at
"/home/garuda/src/modules/umount/umount.conf"
"/etc/calamares/modules/umount.conf"
"/usr/share/calamares/modules/umount.conf"
CppJobModule "umount@umount" loading complete.
21:56:24 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
21:56:24 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
21:56:24 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
21:56:24 [6]: void Config::xkbApply()
xkbmap selection changed to: "us" - ""
21:56:25 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= "IN"
21:56:25 [6]: void setCountry(Config*, const QString&, Calamares::GeoIP::Handler*)
Unusable country code "IN" (no suitable translation)
21:56:25 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 2
"partition"
"welcome"
21:56:25 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 32104880537
enoughStorage : true
RAM : 2684354560
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
21:56:25 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
21:56:26 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
21:56:27 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
21:56:28 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
21:56:30 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
21:56:31 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
21:56:32 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
Seems to loop around Remaining modules: 1 "partition"
and sometimes after looping for long or short, it works and sometimes keeps looping indefinitely.
2.Logs after closing Calamares(not the terminal window from which it was launched) after which previous instances were recorded running in terminal :
Shutting down Calamares...
Finished shutdown.
21:54:53 [2]: WARNING (Qt): QEventLoop: Cannot be used without QApplication
Weirdly tho, using both commands in terminal on fresh boot for the first time makes the installer now launch correctly after 30-40 or 20 secs but upon closing(successfully) and re launching borks everything. Sames happens if I now launch the installer from dock or desktop unlike before where it waited infinitely on first start. Strange
Optional To Read (Not crucially necessary)
Using this command , the first time calamares launches fine with a 30-40 second module wait time, however opening and closing it(the terminal window from which it was launched as well eliminating previous instance) it causes it to sometimes or sometimes not loop indefinitely with the same logs, tested 2 times on 2 fresh restarts in the USB.
I tried further with sudo -E /user/bin/calamares_polkit %f -d -style kvantum
on fresh boots and got same results.
Using both commands on fresh boots regardless of wifi encryption settings, gives sames logs and loops around the same module as well. Can’t say for launching from desktop.
Inxi
from installation(successfully booted & installed system on my hard-disk):
Kernel: 6.11.8-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4e8b76c6-e07f-4eae-9284-4966c848eda1 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A wm: kwin_x11 with: krunner
Type: Desktop System: HP product: HP All-in-One 22-df0xxx v: N/A
serial: <filter> Chassis: type: 13 serial: <filter>
Mobo: HP model: 87A4 v: 10100 serial: <filter> part-nu: 1V6C4AA#ACJ
uuid: 327aa59e-299d-3c50-ecb5-c3bf16a7ecb2 UEFI: AMI v: F.36
date: 08/07/2023
Info: model: Intel Core i3-1005G1 socket: U3E1 bits: 64 type: MT MCP
arch: Ice Lake gen: core 10 level: v4 note: check built: 2019-21
process: Intel 10nm family: 6 model-id: 0x7E (126) stepping: 5
microcode: 0xC6
smt: enabled cache: L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB
desc: 2x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2105 min/max: 400/3400 base/boost: 1200/1200 scaling:
driver: intel_pstate governor: powersave volts: 0.7 V ext-clock: 100 MHz
cores: 1: 2105 2: 2105 3: 2105 4: 2105 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:6
chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
Display: unspecified server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
Monitor-1: eDP-1 model: HP ALL-in-One serial: <filter> built: 2019
res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2 size: 476x268mm (18.74x10.55")
diag: 546mm (21.5") ratio: 16:9 modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (ICL GT1)
device-ID: 8086:8a56 memory: 3.68 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 7 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 24.2.7-arch1.1
device-ID: 8086:8a56 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_icl
API: ALSA v: k6.11.8-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.6 status: n/a (root, process) with:
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:5 chip-ID: 0bda:b00a
Local Storage: total: 960.17 GiB used: 150.09 GiB (15.6%)
model: WD10EZEX-60WN4A1 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 1A03 temp: 38 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 63d 23h cycles: 4174
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 45.41 GiB size: 45.41 GiB (100.00%)
used: 28.13 GiB (62.0%) fs: btrfs block-size: 4096 B dev: /dev/sda12
maj-min: 8:12
used: 584 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda8 maj-min: 8:8
ID-3: /home raw-size: 45.41 GiB size: 45.41 GiB (100.00%)
maj-min: 8:12
ID-4: /var/log raw-size: 45.41 GiB size: 45.41 GiB (100.00%)
maj-min: 8:12
ID-5: /var/tmp raw-size: 45.41 GiB size: 45.41 GiB (100.00%)
maj-min: 8:12
ID-1: swap-1 type: zram size: 7.53 GiB used: 99.2 MiB (1.3%) priority: 100
ID-2: swap-2 type: partition size: 3.99 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda9 maj-min: 8:9
System Temperatures: cpu: 44.0 C mobo: N/A
Memory: total: 8 GiB available: 7.53 GiB used: 2.04 GiB (27.1%) igpu: 60 MiB
Processes: 215 Power: uptime: 7h 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1308 libs: 380 tools: octopi,paru,yay
Compilers: gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
System install date: 2024-11-16
Last full system update: 2024-11-16 ↻
Windows dual boot: Yes
Inxi from Live USB:
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=garuda
root=miso:LABEL=GARUDA_DR460NIZED_BIRDOFPREY quiet systemd.show_status=1
checksum=y driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
serial: <superuser required> Chassis: type: 13 serial: <superuser required>
Mobo: HP model: 87A4 v: 10100 serial: <superuser required>
part-nu: 1V6C4AA#ACJ uuid: <superuser required> UEFI: AMI v: F.36
date: 08/07/2023
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xC4
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
Speed (MHz): avg: 3400 high: 3401 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3401 2: 3400 3: 3400
4: 3400 bogomips: 9523
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1
device-ID: 8086:8a56 memory: 7.35 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
UHD Graphics (ICL GT1) driver: mesa intel v: 24.0.5-arch1.1
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
Local Storage: total: 960.17 GiB used: 0 KiB (0.0%)
model: WD10EZEX-60WN4A1 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A03 scheme: GPT
ID-1: swap-1 type: zram size: 7.53 GiB used: 139.5 MiB (1.8%)
System Temperatures: cpu: 76.0 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.53 GiB used: 3.04 GiB (40.4%)
Processes: 199 Power: uptime: 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.98 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1305 libs: 372 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
Hope it gets inspected.
