Pacman constantly says that another package manager is running even though its not. I did delete the db.lck file and also run "pacman -Syu --debug" which gave me this at the end
debug: got error 10 at alpm_db_update (../lib/libalpm/be_sync.c: 161) : unable to lock database
debug: failed to sync dbs: unable to lock database
error: failed to synchronize all databases (unable to lock database)
debug: unregistering database 'local'
debug: unregistering database 'core'
debug: unregistering database 'extra'
debug: unregistering database 'community'
debug: unregistering database 'multilib'
debug: unregistering database 'wine-lol'
debug: unregistering database 'chaotic-aur'
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/.snapshots/88/snapshot/boot/vmlinuz-linux-zen
root=UUID=8043ca71-0be4-4533-939d-aa93e0996b5f quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 amd_iommu=on
rootflags=noatime,space_cache,autodefrag,compress=zstd,discard=async,ssd,[email protected]/.snapshots/88/sna
pshot
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <filter>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <filter> UEFI: American Megatrends v: F51
date: 07/29/2020
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86228
Speed: 2826 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2826 2: 2357
3: 2409 4: 2406 5: 2809 6: 2640 7: 2376 8: 3245 9: 3333 10: 2576 11: 2425 12: 3031
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: Micro-Star MSI
driver: amdgpu v: kernel bus-ID: 06:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5") s-diag: 599mm (23.6")
Monitor-1: HDMI-A-0 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8")
diag: 611mm (24.1")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.42.0 5.14.12-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 08:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA RC30-026902 Gaming Headset [Nari Essential Wireless Receiver] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2 chip-ID: 1532:051e class-ID: 0300
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 1.58 TiB used: 609.86 GiB (37.6%)
ID-1: /dev/sda maj-min: 8:0 model: SATA3 240GB SSD size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8B0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000AAKS-07A7B2 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3B01
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
serial: <filter> rev: CC43 scheme: GPT
Partition: ID-1: / raw-size: 222.95 GiB size: 222.95 GiB (100.00%) used: 144.64 GiB (64.9%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 25.9 MiB (26.9%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 222.95 GiB size: 222.95 GiB (100.00%) used: 144.64 GiB (64.9%) fs: btrfs
ID-4: /var/log raw-size: 222.95 GiB size: 222.95 GiB (100.00%) used: 144.64 GiB (64.9%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 222.95 GiB size: 222.95 GiB (100.00%) used: 144.64 GiB (64.9%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 4.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 56.8 C mobo: 16.8 C gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 564
Info: Processes: 357 Uptime: 16m wakeups: 0 Memory: 15.58 GiB used: 4.17 GiB (26.8%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1881 lib: 542
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
