Newb here.
I have a display issue for my Wacom Cintiq 27QHD Touch and Sony Bravia TV I use as a monitor. When I try to draw on the artist tablet or use the finger input, it only allows the input on the other monitor. I tried going into settings to set up the tablet and even the "calibrate" setting doesn't work. I'm pretty sure it's the X11 settings causing the issue. Am I just a dumb newb? lol
Any ideas? I really want to make a few wallpapers for Garuda in Garuda Linux. haha
Here is my system readout;
โญโ[email protected] in ~ took 14ms
[๐ด] ร garuda-inxi
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=66e9c8f0-2514-4c99-8d71-9707f1492f7a rw [email protected]
quiet
cryptdevice=UUID=90b6f859-0910-4c64-abdb-b7ded33ca159:luks-90b6f859-0910-4c64-abdb-b7ded33ca159
root=/dev/mapper/luks-90b6f859-0910-4c64-abdb-b7ded33ca159 splash
resume=/dev/mapper/luks-68229958-a59d-46c2-9dea-2e5a3011716b loglevel=3
Type: Desktop Mobo: ASRock model: X370 Taichi serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P3.20 date: 09/08/2017
Info: model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001129
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3134 high: 3492 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3100 2: 3379
3: 2993 4: 3111 5: 3207 6: 2976 7: 3120 8: 3492 9: 3040 10: 3259 11: 2990
12: 2991 13: 3483 14: 3012 15: 3038 16: 2965 bogomips: 115193
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: eVga.com.
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 0e:00.0
chip-ID: 10de:1e07 class-ID: 0300
Device-2: Tobii AB EyeChip type: USB driver: uvcvideo bus-ID: 5-3.1:5
chip-ID: 2104:0127 class-ID: 0e02 serial: <filter>
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 6535x2160 s-dpi: 107 s-size: 1552x513mm (61.1x20.2")
s-diag: 1635mm (64.4")
Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 109
size: 596x335mm (23.5x13.2") diag: 684mm (26.9")
Monitor-2: DP-5 res: 3840x2160 hz: 60 dpi: 103
size: 950x540mm (37.4x21.3") diag: 1093mm (43")
OpenGL: renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: NVIDIA TU102 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 0e:00.1 chip-ID: 10de:10f7
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 12:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: ASUSTek ASUS ROG 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3:7 chip-ID: 0b05:1815
Device-4: Texas Instruments PCM2900C Audio CODEC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-3.4.4:9
chip-ID: 08bb:29c0 class-ID: 0300
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.44 running: yes
v: kernel bus-ID: 09:00.0 chip-ID: 8086:24fb class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
port: d000 bus-ID: 0b:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp11s0 state: down mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:5 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 12.95 TiB used: 272.69 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P1SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P3CR013
temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A240G
type: SSD serial: <filter> rev: BBF0 scheme: MBR
model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
model: WD5000AZRX-00A8LB0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD30EZRZ-00GXCB0 size: 2.73 TiB block-size: physical: 4096 B
ID-6: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital
model: WD My Book 25EE size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 4004 scheme: GPT
ID-1: / raw-size: 431.28 GiB size: 431.28 GiB (100.00%)
used: 189.59 GiB (44.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-90b6f859-0910-4c64-abdb-b7ded33ca159
ID-2: /home raw-size: 431.28 GiB size: 431.28 GiB (100.00%)
ID-3: /var/log raw-size: 431.28 GiB size: 431.28 GiB (100.00%)
ID-4: /var/tmp raw-size: 431.28 GiB size: 431.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.34 GiB used: 2.5 MiB (0.0%)
ID-2: swap-2 type: partition size: 34.48 GiB used: 0 KiB (0.0%)
mapped: luks-68229958-a59d-46c2-9dea-2e5a3011716b
System Temperatures: cpu: 34.9 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 431 Uptime: 5h 11m wakeups: 1 Memory: 31.35 GiB
used: 13.67 GiB (43.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1624 lib: 486 flatpak: 0
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
Garuda (2.5.3-1):
System install date: 2021-12-24
Last full system update: 2022-02-01
