Hey,
I'm unable to type a w in any application while yakuake is on, regardless of whether it's open. The keypress does register in "Keyboard Visualizer" and works fine if I kill yakuake.
I've looked at yakuakes shortcuts and can't find any that should stop the key.
Any help is greatly appreciated!
Obligatory garuda-inxi
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=593ea6ed-5a5a-4c63-8805-c504826e92b7 rw [email protected]
Type: Laptop System: Acer product: TravelMate P214-52G v: V1.27
Mobo: CML model: Timpani_CM v: V1.27 serial: <superuser required>
UEFI: INSYDE v: 1.27 date: 05/26/2021
ID-1: BAT1 charge: 12.9 Wh (35.5%) condition: 36.3/53.0 Wh (68.6%)
volts: 13.6 min: 15.4 model: PANASONIC AP19B5L type: Li-ion
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3148 high: 4681 min/max: 400/4900 scaling:
driver: intel_pstate governor: performance cores: 1: 4001 2: 4449 3: 4395
4: 4102 5: 722 6: 1238 7: 4681 8: 1596 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Acer Incorporated ALI
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 02:00.0
chip-ID: 10de:1d11 class-ID: 0302
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.2
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Acer Incorporated ALI
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 16.52 GiB (3.5%)
model: PC SN520 SDAPNUW-512G-1014 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20110000 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 270.23 GiB size: 270.23 GiB (100.00%)
used: 16.23 GiB (6.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 24.6 MiB (4.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 150.54 GiB size: 150.54 GiB (100.00%)
used: 280 MiB (0.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 270.23 GiB size: 270.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 270.23 GiB size: 270.23 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 53.0 C pch: 55.0 C mobo: N/A
Processes: 286 Uptime: 10m wakeups: 2 Memory: 15.46 GiB
used: 2.63 GiB (17.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1705 lib: 512 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-02
Last full system update: 2022-05-02
