I've used gardua gamer to install steam, I remember that it hit an error but steam still ran. so I ingored it but I have been having problems with vulcan.
ERROR at /usr/src/debug/vulkan-tools/Vulkan-Tools-1.3.245/vulkaninfo/vulkaninfo.h:679:vkCreateInstance failed with ERROR_OUT_OF_HOST_MEMORY
which is odd considering I have 14GB of ram free.
System info:
Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=82e38dd3-0af5-4c81-a450-39169123e9b8
rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=6a73d440-8a1a-456c-8d1b-a85e38a9225c loglevel=3 ibt=off
Console: pty pts/0 DM: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Alienware product: ASM100 v: N/A serial: Chassis:
type: 3 serial:
Mobo: Dell model: 03V3TG v: A00 serial: UEFI: Alienware v: A05
date: 10/28/2016
Info: model: Intel Core i7-4765T bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3
note: check built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60) stepping: 3
microcode: 0x28
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2621 high: 3000 min/max: 800/3000 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3000 2: 3000 3: 3000 4: 1995 5: 3000 6: 1996 7: 3000 8: 1982
bogomips: 31925
Device-1: NVIDIA GM107M [GeForce GTX 860M] vendor: Dell driver: nvidia v: 530.41.03
alternate: nouveau,nvidia_drm non-free: 530.xx+ status: current (as of 2023-03) arch: Maxwell
code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 2 speed: 5 GT/s bus-ID: 01:00.0 chip-ID: 10de:1392 class-ID: 0300
Display: server: X.org v: 1.21.1.8 driver: X: loaded: nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: nvidia tty: 190x49
API: OpenGL Message: GL data unavailable in console and glxinfo missing.
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 2
speed: 5 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 0.3.69 status: off with: 1: pipewire-pulse status: off 2: wireplumber
status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp4s0 state: down mac:
IF-ID-1: docker0 state: down mac:
IF-ID-2: ztc3q7edgb state: unknown speed: 10000 Mbps duplex: full mac:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 3-5:2
chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address:
Local Storage: total: 1.88 TiB used: 928.31 GiB (48.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST2000LM003 HN-M201RAD size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 0002 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Glide size: 57.3 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.09 TiB size: 1.09 TiB (100.00%) used: 659.87 GiB (59.3%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 1.09 TiB size: 1.09 TiB (100.00%) used: 659.87 GiB (59.3%) fs: btrfs
ID-4: /var/log raw-size: 1.09 TiB size: 1.09 TiB (100.00%) used: 659.87 GiB (59.3%) fs: btrfs
ID-5: /var/tmp raw-size: 1.09 TiB size: 1.09 TiB (100.00%) used: 659.87 GiB (59.3%) fs: btrfs
ID-1: swap-1 type: zram size: 15.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 42.02 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 40 C
Processes: 243 Uptime: 4m wakeups: 0 Memory: 15.56 GiB used: 1.02 GiB (6.6%) Init: systemd
v: 253 default: graphical tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1621
libs: 482 tools: pamac,paru,yay pm: rpm pkgs: 0 Shell: fish v: 3.6.1 running-in: pty pts/0 (SSH)
inxi: 3.3.26
System install date: 2023-02-25
Last full system update: 2023-04-17
