Hi everyone. I've been using Garuda for 2 weeks now and loving it. But I have a small problem caused by my concern of looks and aesthetics. Almost every application I download is automatically themed similar to my Garuda theme but in VS Code, I have to change the theme on my own. I looked at the system settings and Dr460nized uses something like "sweetified" but there is no VS Code theme with the same name. So, my question is, how do my make my VS Code blend in with my Garuda theme and look like a default app like terminals etc.? If there is no chance, what's the color theme closest to Garuda's sweetified theme in VS Code?
Sorry if i gave unnecessary information. Any help will be appreciated.
If you want purple shaded theme then i suggest jellyfish theme which is my personal favorite but if you want to fully similar then unfortunately there isn't any theme for vscode.
Other than this, I don’t think you will get exactly same look as the, for example, the konsole terminal on Garuda. These are made using Qt framework, and they blend very nicely with all KDE apps like dolphin, konsole.
VScode on the other hand is made with Electron, which uses chromium. Chromium is made with GTK.
