VPN import problem
Hello, I'm trying to use protonVPN on Garuda, but the protonVPN GUI app is very bad. Therefore I am trying to import manual config files into my network manager but they don't work. I'm going into network -> connections -> add new connection -> import from file -> error
The config files are correctly imported from protonVPN's website.
I've mailed proton but they're not helping me, they only direct me here (which isn't useful) How to manually configure OpenVPN in Linux - Proton VPN Support
The error code I get is:
Failed to import VPN connection: configuration error: option remote expects between 1 and 3 arguments (line 2)
This error occurs on every single config file
How can I fix it?
Kernel: 6.2.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ac3db51d-0458-4e6e-a36e-12defe2236f9 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME A320I-K v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2203
date: 07/28/2020
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1689 high: 3400 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3400 2: 1550
3: 1550 4: 1550 5: 1376 6: 1550 7: 1550 8: 1550 9: 1550 10: 1547 11: 1550
12: 1550 bogomips: 81440
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1,
HDMI-A-1, HDMI-A-2 bus-ID: 07:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 48.0 C
Monitor-1: DP-2 mapped: DisplayPort-1 model: VG259QM serial: <filter>
built: 2021 res: 1920x1080 dpi: 90 gamma: 1.2 size: 544x303mm (21.42x11.93")
diag: 623mm (24.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 15.0.7 DRM 3.49 6.2.2-zen1-1-zen) direct-render: Yes
vendor: Sapphire driver: snd_hda_intel v: kernel bus-ID: 2-6:3 pcie:
chip-ID: 041e:3256 class-ID: 0300 gen: 3 speed: 8 GT/s serial: <filter>
lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaf0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
Device-3: Creative Sound BlasterX G6 type: USB
Sound API: ALSA v: k6.2.2-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
IF-ID-1: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Local Storage: total: 447.13 GiB used: 247.05 GiB (55.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37480G
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 56R8 scheme: GPT
used: 247.05 GiB (55.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.55 GiB used: 147 MiB (0.9%) priority: 100
System Temperatures: cpu: 32.2 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 768
Processes: 376 Uptime: 5h 15m wakeups: 0 Memory: 15.55 GiB
used: 4.6 GiB (29.6%) Init: systemd v: 253 default: graphical
pkgs: 1524 libs: 456 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2023-02-13
Last full system update: 2023-03-21 ↻
You may need to install this special library for that to work: GitHub - ProtonVPN/protonvpn-nm-lib
The Arch-equivalent of this set of instructions is here: ProtonVPN - ArchWiki
Another worthwhile consideration would be to learn how to use the CLI version of the app: ProtonVPN - ArchWiki
For a VPN, learning to use the CLI version is generally not that bad because there are probably less than half a dozen commands you will ever use. Connect, set the killswitch on, change servers, set the killswitch off, disconnect...that's basically it unless you need to whitelist IPs or other weird stuff.
Who knows, you might even turn into a weirdo like me and grow to prefer the CLI version of the app. :wink:
Also to add, sometimes the GUI's from a particular VPN company have controls built in for them to limit you in some way, such as traffic speed, etc. I find it is always best to not use them but opt for built in protocols such as OpenVPN option (which I think ProtonVPN has) or L2TP/IPsec, all install info in the ArchWiki.
Thanks guys
