Hi there, I am fairly new to linux, I am using Garuda KDE Dr460nized.
So, Volume down, up and mute keys aren't working anymore, they used to be working and suddenly stopped (Fn + F1,F2,F3 keys).
The rest of the function keys works normally, and these three used to work but suddenly they just stopped.
how can I solve this?
Here is my terminal output.
System: Kernel: 5.13.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5a31376c-873a-4e8e-bc94-fc848ec1ba42
systemd.unified_cgroup_hierarchy=1 resume=UUID=937e0c91-c630-428c-b79a-269814b701cb loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LI_FX506LI v: 1.0
Mobo: ASUSTeK model: FX506LI v: 1.0 serial: <filter> UEFI: American Megatrends v: FX506LI.309
date: 02/02/2021
Battery: ID-1: BAT1 charge: 16.9 Wh (39.6%) condition: 42.7/48.2 Wh (88.7%) volts: 10.7 min: 11.9
model: ASUS A32-K55 type: Li-ion serial: N/A status: Discharging
CPU: Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 39999
Speed: 3399 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 3399 2: 4461 3: 3601 4: 3400
5: 3402 6: 4232 7: 3833 8: 4163
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK driver: nvidia
v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 1-7:2
chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.8-zen1-1-zen running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 1.14 TiB used: 89.95 GiB (7.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530 SDBPNPZ-256G-1002
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-22Z10T1 size: 931.51 GiB
serial: <filter> rev: 1A04 scheme: MBR
Partition: ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 17.79 GiB (25.4%) fs: btrfs
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: /boot/efi raw-size: 512.7 MiB size: 511.7 MiB (99.80%) used: 580 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%) used: 72.15 GiB (72.2%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%) used: 17.79 GiB (25.4%) fs: btrfs
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%) used: 17.79 GiB (25.4%) fs: btrfs
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7
maj-min: 259:7
ID-2: swap-2 type: zram size: 7.61 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 60.0 C mobo: 27.8 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 302 Uptime: 21m wakeups: 1 Memory: 7.61 GiB used: 3.65 GiB (48.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1368 lib: 339
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
