After I updated my system, the volume keys on my keyboard stopped working. I have few keys on the top of my keyboard that do some special action. The mute, volume up, volume down buttons stopped working. Search key or the stop/pause works fine.
garuda-inxi output:
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e1fd8aa5-3909-4e25-beac-5e11b1b3a928 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: STRIX B250G GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0809
date: 07/07/2017
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
desc: 1x6 MiB
Speed (MHz): avg: 2272 high: 3788 min/max: 800/3800 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 3701 3: 3788
4: 800 bogomips: 27199
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ASUSTeK driver: nvidia
v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Screen-1: 0 s-res: 5520x1080 s-dpi: 90 s-size: 1558x312mm (61.34x12.28")
s-diag: 1589mm (62.56")
Monitor-1: DP-1 pos: left res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.66x11.65") diag: 559mm (22") modes: N/A
Monitor-2: HDMI-0 pos: primary,center res: 1920x1080 hz: 60 dpi: 82
Monitor-3: HDMI-1 pos: right res: 1920x1080 hz: 60 dpi: 82
Monitor-4: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 direct-render: Yes
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-3: Kingston HyperX Cloud II Wireless
lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0951:1718 class-ID: 0300
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api
IF-ID-1: br0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
Local Storage: total: 1.02 TiB used: 156.7 GiB (15.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SUV400S37120G
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 87RA scheme: GPT
model: WD10EZRZ-00HTKB0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
used: 76.38 GiB (68.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-4: /var/log raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 34.8 MiB (0.2%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 303 Uptime: 5m wakeups: 3 Memory: total: 16 GiB
available: 15.56 GiB used: 5.9 GiB (37.9%) Init: systemd v: 254
Packages: 1769 pm: dpkg pkgs: 0 pm: pacman pkgs: 1756 libs: 410
tools: octopi,paru pm: snap pkgs: 13 Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date: 2021-10-22
Last full system update: 2023-09-16
