There is one lingering problem that I haven't found a solution to.
Every now and then (very rarely), the volume starts jumping up to 100% and down to 0%. The rest of the time it works perfectly fine.
I thought it could be xanmod kernel, that gives me another audio glitching sound problem when I open the audio panel. I switched back to zen kernel and saw the same problem again, so that discards that.
Perhaps it's the Corsair K95 Platinum keyboard sending wheel signals? Closed ckb-next
and the volume wheel doesn't work anymore, and the volume keeps jumping. That discards that.
It might happen after 1 or 2 days of use, seemingly randomly, so it's very hard to reproduce. Yesterday I had to continually fight with the volume just to be able to finish watching a video.
Any idea what could be causing this?
Kernel: 6.0.3-x64v2-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw [email protected]
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 41.6 Wh (99.5%) condition: 41.8/58.8 Wh (71.2%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3599 high: 3601 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3594
4: 3600 5: 3600 6: 3601 7: 3600 8: 3600 9: 3601 10: 3600 11: 3601 12: 3600
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 515.76
alternate: nvidiafb,nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-2
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x82ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6.0 NVIDIA 515.76 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 1-1.3:6
alternate: snd_sof_pci_intel_cnl chip-ID: 08bb:29b0 bus-ID: 00:1f.3
class-ID: 0300 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
Sound API: ALSA v: k6.0.3-x64v2-xanmod1-1 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 1.63 TiB used: 1.29 TiB (79.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT275MX300SSD4
size: 256.17 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-1: / raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
used: 419.24 GiB (89.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:3
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
ID-4: /var/log raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 468.84 GiB size: 468.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 1.42 GiB (9.2%)
System Temperatures: cpu: 82.0 C pch: 86.0 C mobo: N/A gpu: nvidia
temp: 75 C
Processes: 370 Uptime: 1h 41m wakeups: 1 Memory: 15.47 GiB
used: 11.33 GiB (73.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages:
pm: pacman pkgs: 2092 libs: 552 tools: octopi,pamac,paru pm: appimage
pkgs: 0 Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2021-11-24
Last full system update: 2023-02-22
Failed units: systemd-sysctl.service systemd-oomd.socket
