Can anybody recommend a VNC server with a nice settings GUI, ideally one within System Settings?
tight vnc is an easyone
Unfortunately I'm getting a build error trying to install that. Any thoughts?
reparing...
Cloning tightvnc build files...
Checking tightvnc dependencies...
Resolving dependencies...
Checking inter-conflicts...
Building tightvnc...
==> Making package: tightvnc 1.3.10-10 (Mon 02 Aug 2021 13:03:58 BST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Found tightvnc-1.3.10_unixsrc.tar.bz2
-> Found rgb.txt
-> Found vncserver.service
==> Validating source files with sha256sums...
tightvnc-1.3.10_unixsrc.tar.bz2 ... Passed
rgb.txt ... Passed
vncserver.service ... Passed
tightvnc.png ... Passed
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Extracting tightvnc-1.3.10_unixsrc.tar.bz2 with bsdtar
==> Starting prepare()...
[tightvnc] Generating desktop file... ok
==> Removing existing $pkgdir/ directory...
==> Starting build()...
imake -DUseInstalled -I/usr/lib/X11/config
make Makefiles
make[1]: Entering directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc'
making Makefiles in libvncauth...
make[2]: Entering directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc'
make[2]: Leaving directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc'
make[2]: Entering directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/libvncauth'
make[2]: Nothing to be done for 'Makefiles'.
make[2]: Leaving directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/libvncauth'
making Makefiles in vncviewer...
make[2]: Entering directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/vncviewer'
make[2]: Leaving directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/vncviewer'
making Makefiles in vncpasswd...
make[2]: Entering directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/vncpasswd'
make[2]: Leaving directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/vncpasswd'
making Makefiles in vncconnect...
make[2]: Entering directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/vncconnect'
make[2]: Leaving directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc/vncconnect'
make[1]: Leaving directory '/var/tmp/pamac-build-sam/tightvnc/src/vnc_unixsrc'
make depend
depending in ./libvncauth...
gccmakedep -- -I. -I../include -I/usr/include -Dlinux -D__amd64__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DFUNCPROTO=15 -DNARROWPROTO -- vncauth.c d3des.c
depending in ./vncviewer...
gccmakedep -- -I../include -I. -I/usr/local/include -I/usr/local/include -I/usr/include -I/usr/include -Dlinux -D__amd64__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DFUNCPROTO=15 -DNARROWPROTO -- argsresources.c caps.c colour.c cursor.c desktop.c dialogs.c fullscreen.c listen.c misc.c popup.c rfbproto.c selection.c shm.c sockets.c tunnel.c vncviewer.c
depending in ./vncpasswd...
gccmakedep -- -I../include -I/usr/include -Dlinux -D__amd64__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DFUNCPROTO=15 -DNARROWPROTO -- vncpasswd.c
depending in ./vncconnect...
gccmakedep -- -I/usr/include -Dlinux -D__amd64__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DFUNCPROTO=15 -DNARROWPROTO --
make all
making all in ./libvncauth...
gcc -O2 -fno-strength-reduce -fno-strict-aliasing -I. -I../include -I/usr/include -Dlinux -D__amd64__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DFUNCPROTO=15 -DNARROWPROTO -c -o vncauth.o vncauth.c
In file included from /usr/include/bits/libc-header-start.h:33,
from /usr/include/stdio.h:27,
from vncauth.c:24:
/usr/include/features.h:187:3: warning: #warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE" [-Wcpp]
187 | # warning "_BSD_SOURCE and _SVID_SOURCE are deprecated, use _DEFAULT_SOURCE"
vncauth.c: In function âvncEncryptAndStorePasswdâ:
vncauth.c:60:13: warning: implicit declaration of function âvncEncryptAndStorePasswd2â; did you mean âvncEncryptAndStorePasswdâ? [-Wimplicit-function-declaration]
60 | return (vncEncryptAndStorePasswd2(passwd, NULL, fname) == 0);
vncauth.c: In function âvncDecryptPasswdFromFileâ:
vncauth.c:131:13: warning: implicit declaration of function âvncDecryptPasswdFromFile2â; did you mean âvncDecryptPasswdFromFileâ? [-Wimplicit-function-declaration]
131 | if (vncDecryptPasswdFromFile2(fname, passwd, NULL) == 0) {
vncauth.c: In function âvncRandomBytesâ:
vncauth.c:211:28: warning: implicit declaration of function âtimeâ [-Wimplicit-function-declaration]
211 | seed = (unsigned int)time(0) ^ (unsigned int)getpid();
gcc -O2 -fno-strength-reduce -fno-strict-aliasing -I. -I../include -I/usr/include -Dlinux -D__amd64__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -DFUNCPROTO=15 -DNARROWPROTO -c -o d3des.o d3des.c
rm -f libvncauth.a
ar clq libvncauth.a vncauth.o d3des.o
ar: libdeps specified more than once
make[2]: *** [Makefile:1042: libvncauth.a] Error 1
make[1]: *** [Makefile:1047: all] Error 2
make: *** [Makefile:1037: World] Error 2
==> ERROR: A failure occurred in build().
Aborting...
Just tested it myself same error
l hate build errors
Have you tried the repos?
pacman -Ss vnc
In the past I used tigervnc (a fork from tightvnc) from the arch repo and it was ok (althoguh I used it only for a short period).
Btw, if you want remote connection, you can also have a look at nomachine and dwservice.
Dwservice is free and really easy to use, but its security may be questionable.
Nomachine is nice for connection in the same network. It is again complicated for global connection.
Also, I heard that tigervnc in nice, but don't expect it to be easy to use. It currently don't have GUI setup. But we are lucky to have Archwiki page dedicated to it
Thanks guys.
Trying Tiger as per the wiki, but I'm getting an error on startup:
[đ] Ă systemctl --user status x0vncserver.service
Ă x0vncserver.service - Remote desktop service (VNC)
Loaded: loaded (/home/sam/.config/systemd/user/x0vncserver.service; enabled; vendor preset: enabled)
Active: failed (Result: timeout) since Mon 2021-08-02 20:33:18 BST; 1min 9s ago
Process: 2427 ExecStartPre=/bin/sh -c while ! pgrep -U "$USER" Xorg; do sleep 2; done (code=killed, signa>
CPU: 359ms
Aug 02 20:31:48 sams-laptop systemd[2419]: Starting Remote desktop service (VNC)...
Aug 02 20:33:18 sams-laptop systemd[2419]: x0vncserver.service: start-pre operation timed out. Terminating.
Aug 02 20:33:18 sams-laptop systemd[2419]: x0vncserver.service: Control process exited, code=killed, status=1>
Aug 02 20:33:18 sams-laptop systemd[2419]: x0vncserver.service: Failed with result 'timeout'.
Aug 02 20:33:18 sams-laptop systemd[2419]: Failed to start Remote desktop service (VNC).
It worked when I ran it manually with x0vncserver -rfbauth ~/.vnc/passwd, it's just trying to start it with systemd that it's failing. My config file is exactly as in the wiki:
ââsam@sams in ~ took 43ms
[đ´] Ă cat ~/.config/systemd/user/x0vncserver.service
File: /home/sam/.config/systemd/user/x0vncserver.service
[Unit]
Description=Remote desktop service (VNC)
[Service]
Type=simple
# wait for Xorg started by ${USER}
ExecStartPre=/bin/sh -c 'while ! pgrep -U "$USER" Xorg; do sleep 2; done'
ExecStart=/usr/bin/x0vncserver -rfbauth %h/.vnc/passwd
# or login with your username & password
#ExecStart=/usr/bin/x0vncserver -PAMService=login -PlainUsers=${USER} -SecurityTypes=TLSPlain
[Install]
WantedBy=default.target
Woah, hold on - the wiki says "create a systemd unit as follows replacing the user and the options with the desired ones" - does that mean $USER? I assumed that was a variable that contained the name of the current user automatically?
OK, I was right the first time, $USER is the current user automagically.
So, my problem is the prerequisite line:
If I comment this out the service works, but fails on reboot, presumably because itâs trying to start before the display server is running?
So, this is waiting for a running progress called Xorg, belonging to the current user, right? pgrep -U "$USER" Xorg doesnât find anything - is the problem that Garuda uses Wayland? Iâve tried pgrep -U $USER wayland but that hasnât found anything either.
I set it to wait for plasmashell. I donât know if thatâs the recommended process to use, but it seems to be working fine, even after a reboot
Please, post the method you used for this.
I changed the line
to
ExecStartPre=/bin/sh -c 'while ! pgrep -U "$USER" plasmashell; do sleep 2; done'
If people think this is the right solution (there may be a better process to wait for, Iâm no expert here) perhaps we should update the wiki? Lots of people use Wayland now, right?
I believe you can use multiple ExecStartPre= statements, and that may be a little cleaner way to execute the commands rather than chaining them all. But if it works who am I to say otherwise.
Iâm not sure what you mean - I havenât chained anything, Iâve just changed the name of the process it pgreps for inside the while loop.
Nevermind it's all good, I didn't read it carefully enough.
