Vmware workstation was working ok for me before the last update. I am able to start the application, however when I go to resume or power a virtual machine. I get the following error:
Unable to change virtual machine power state: Transport (VMDB) error -14: Pipe connection has been broken.
Any assistance with this would be greatly appreciated. I use VMware extensively for work (Windows 11 VM)
dalto
18 December 2023 20:22
2
Are you using the AUR package? If not, do that.
SGS
19 December 2023 00:07
3
We are missing the garuda-inxi
Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
same result from using AUR package. Looks like I have to provide more info.
â•─reggie@garudaG in ~
╰─λ garuda-inxi
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ad623bc2-60df-4d41-872c-0901cb552a02 rw rootflags=subvol=@
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM
v: 45.0.1 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 00D5DG v: A00 serial: <superuser required> UEFI: Dell
v: 1.24.0 date: 11/10/2023
ID-1: BAT0 charge: 12.7 Wh (24.9%) condition: 51.1/95.1 Wh (53.7%)
volts: 11.6 min: 11.4 model: BYD DELL F8CPG15 type: Li-poly serial: <filter>
status: charging
Info: model: 11th Gen Intel Core i9-11900H bits: 64 type: MT MCP
microcode: 0x4E
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 839 high: 1118 min/max: 800/4900:4800 scaling:
5: 800 6: 800 7: 800 8: 1112 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 1118 bogomips: 79872
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-5, DP-6, DP-7, DP-8 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 01:00.0 chip-ID: 10de:2520
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-11:3
chip-ID: 0c45:6a11 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.00x12.52")
s-diag: 599mm (23.6")
Monitor-1: eDP-1 model: Sharp 0x1517 built: 2021 res: 1920x1200 hz: 60
dpi: 133 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 3840x2400
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0026
Local Storage: total: 953.87 GiB used: 191.64 GiB (20.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 36310029 temp: 37.9 C
ID-1: / raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
used: 191.52 GiB (60.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw-size: 150 MiB size: 146 MiB (97.33%)
used: 120.4 MiB (82.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
ID-4: /var/log raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
ID-5: /var/tmp raw-size: 316.34 GiB size: 316.34 GiB (100.00%)
ID-1: swap-1 type: partition size: 18.63 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: swap-2 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 67.0 C mobo: 43.0 C
Fan Speeds (rpm): cpu: 1918
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 469 Uptime: 4m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.08 GiB used: 7.41 GiB (23.8%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1675
pm: pacman pkgs: 1608 libs: 460 tools: gnome-software,pamac,paru pm: flatpak
pkgs: 67 Shell: fish v: 3.6.4 running-in: gnome-terminal inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-10-30
Last full system update: 2023-12-18 ↻
Failed units: vpn-unlimited-daemon.service
Bro
19 December 2023 13:31
6
The swoosh indicates that a reboot is necessary since your last update. Please do so and see if the below error persists.
system
Closed
2 January 2024 13:32
7
