I will start with this…
╭─fenris@fenris in ~ as 🧙 took 26ms
╰─λ sudo garuda-inxi
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cd6e149b-2970-476f-b742-e3dc1120bedc rw rootflags=subvol=@
quiet rd.luks.uuid=264cadad-c8c3-46fe-b132-32f30ff8b69c
rd.luks.uuid=0dd705d1-74f7-4ae7-8f55-96ae57f524b8
resume=/dev/mapper/luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8 loglevel=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: N/A part-nu: 01
uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends LLC.
v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 socket: U3E1 bits: 64 type: MCP arch: Alder Lake
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x17
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3114 high: 3196 min/max: 700/3400 base/boost: 2871/3400
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 3176 2: 2997 3: 3087 4: 3196 bogomips: 6451
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46d1
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.4:7
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer G247HYL serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.6-arch1.1 (LLVM
Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
chip-ID: 8086:54c8 class-ID: 0403
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: n/a (root, process) with:
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:5
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0026
Local Storage: total: 4.55 TiB used: 3.35 TiB (73.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 76.8 C
SMART: yes health: PASSED on: 110d 22h cycles: 25
read-units: 95,495,920 [48.8 TB] written-units: 25,128,119 [12.8 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
family: Barracuda 2.5 5400 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5400
serial: <filter> fw-rev: 0001 temp: 68 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 232d 15h cycles: 152
read: 23.82 TiB written: 26.29 TiB Old-Age: g-sense error rate: 106
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LM015-2E8174
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0202 scheme: MBR
ID-1: / raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
used: 485.69 GiB (53.1%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 254:1 mapped: luks-264cadad-c8c3-46fe-b132-32f30ff8b69c
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-4: /var/log raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
mapped: luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8
ID-2: swap-2 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 94.0 C mobo: N/A
Memory: total: 16 GiB available: 15.4 GiB used: 6.44 GiB (41.8%)
igpu: 60 MiB
Processes: 335 Power: uptime: 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 2001 libs: 509 tools: pamac,paru,yay Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
running-in: xfce4-terminal inxi: 3.3.35
System install date: 2024-04-11
Last full system update: 2024-08-25
Failed units: vmware-networks-server.service vmware-workstation-server.service vmware.service
╭─fenris@fenris in ~ as 🧙 took 3s
╰─λ
So, I installed a whole bunch of updates and everything was fine till I reboot my computer. Things started behaving sluggish over time of installing updates and not restarting the operating system, so I finally did that now.
I restart my VMware Workstation application to load my macOS VM’s and I get this annoying error:
And you get this after clicking the OK button:
Then the VM crashes, and you get this after clicking the OK button:
After that, I consult a web search and I find these issues how to solve it (kinda):
https://bbs.archlinux.org/viewtopic.php?id=273846
This tells me that something in the linux-headers updates did this somehow, but I don’t know how to fix these issues in Garuda. I don’t think I should need to git clone the header files like you would if this were native Arch.
Any ideas?
