I recently installed VMWare Workstation 17 to run a Windows 11 VM, but it won’t connect to my network. None of the connection options work, even if I run it as root. Any searches point me to running VMWare on Windows.
Kernel: 6.12.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=abc48267-0174-400d-978f-b7198dff323c rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
UEFI: American Megatrends v: 2423 date: 08/10/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1727 min/max: 550/4951 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1727 2: 1727 3: 1727
4: 1727 5: 1727 6: 1727 7: 1727 8: 1727 9: 1727 10: 1727 11: 1727 12: 1727
13: 1727 14: 1727 15: 1727 16: 1727 17: 1727 18: 1727 19: 1727 20: 1727
21: 1727 22: 1727 23: 1727 24: 1727 bogomips: 177260
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6950 XT]
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3,Writeback-1
bus-ID: 0c:00.0 chip-ID: 1002:73a5 class-ID: 0300
gpu: amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-2 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 18.1.8 DRM 3.59 6.12.7-zen1-1-zen) device-ID: 1002:73a5
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: N/A device-ID: 1002:73a5
bus-ID: 0c:00.1 chip-ID: 1002:ab28 class-ID: 0403
API: ALSA v: k6.12.7-zen1-1-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:7
chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
Device-3: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
driver: N/A type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:4 chip-ID: 0bda:8812 class-ID: 0000 serial: <filter>
Local Storage: total: 18.65 TiB used: 3.22 TiB (17.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 28.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST20000NE000-3G5101
size: 18.19 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01 scheme: GPT
ID-1: / raw-size: 99.97 GiB size: 99.97 GiB (100.00%)
used: 95.99 GiB (96.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27.1 MiB (28.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 99.97 GiB size: 99.97 GiB (100.00%)
ID-4: /var/log raw-size: 99.97 GiB size: 99.97 GiB (100.00%)
ID-5: /var/tmp raw-size: 99.97 GiB size: 99.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 125.68 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24
System Temperatures: cpu: 47.1 C mobo: N/A gpu: amdgpu temp: 40.0 C
mem: 32.0 C
Memory: total: 128 GiB note: est. available: 125.68 GiB
used: 5.17 GiB (4.1%)
Processes: 504 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 50.26 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2014 libs: 558 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-07-24
Last full system update: 2024-12-30
