Reboot and follow the template.
garuda-inxiin the body of the post (not linked externally, or collapsed with the “hide details” feature)
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Please.
Kernel: 6.14.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=e11f7297-9fb5-470c-a7fc-3839861c704a rw rootflags=subvol=@
Desktop: GNOME v: 48.0 tk: GTK v: 3.24.49 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Garuda base: Arch Linux
Type: Vmware System: VMware product: VMware Virtual Platform v: N/A
serial: <superuser required> Chassis: No Enclosure type: 1
Mobo: Intel model: 440BX Desktop Reference Platform
serial: <superuser required> uuid: <superuser required> BIOS: Phoenix
v: 6.00 date: 11/12/2020
Info: model: AMD Ryzen 5 5600 bits: 64 type: SMP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: N/A
Topology: cpus: 4x dies: 1 clusters: 1 cores: 1 smt: <unsupported> cache:
L1: 4x 64 KiB (256 KiB) desc: d-1x32 KiB; i-1x32 KiB L2: 4x 512 KiB (2 MiB)
desc: 1x512 KiB L3: 4x 32 MiB (128 MiB) desc: 1x32 MiB
Speed (MHz): avg: 3500 min/max: N/A cores: 1: 3500 2: 3500 3: 3500 4: 3500
bogomips: 27999
Flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: VMware SVGA II Adapter driver: vmwgfx v: 2.20.0.0 ports:
active: Virtual-1 empty: Virtual-2, Virtual-3, Virtual-4, Virtual-5,
Virtual-6, Virtual-7, Virtual-8 bus-ID: 00:0f.0 chip-ID: 15ad:0405
compositor: gnome-shell driver: X: loaded: vmware unloaded: modesetting
alternate: fbdev,vesa gpu: vmwgfx display-ID: :0 screens: 1
Screen-1: 0 s-res: 1718x928 s-dpi: 96 s-size: 454x245mm (17.87x9.65")
s-diag: 516mm (20.31")
Monitor-1: Virtual-1 mapped: Virtual1 res: mode: 1718x928 hz: 60
scale: 100% (1) size: N/A modes: max: 1718x928 min: 640x480
Info: Tools: api: vulkaninfo x11: xdpyinfo, xprop, xrandr
Device-1: Ensoniq ES1371/ES1373 / Creative Labs CT2518 driver: snd_ens1371
v: kernel bus-ID: 02:02.0 chip-ID: 1274:1371 class-ID: 0401
API: ALSA v: k6.14.2-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel 82371AB/EB/MB PIIX4 ACPI vendor: VMware Virtual Machine
type: network bridge driver: N/A modules: i2c_piix4 port: N/A
bus-ID: 00:07.3 chip-ID: 8086:7113 class-ID: 0680
Device-2: Intel 82545EM Gigabit Ethernet vendor: VMware PRO/1000 MT
Single Port driver: e1000 v: kernel port: 2000 bus-ID: 02:01.0
chip-ID: 8086:100f class-ID: 0200
IF: ens33 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 50 GiB used: 7.11 GiB (14.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: VMware model: Virtual S size: 50 GiB
block-size: physical: 512 B logical: 512 B tech: N/A serial: N/A fw-rev: 1.0
scheme: MBR
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 7.11 GiB (14.2%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 50 GiB size: 50 GiB (100.00%) used: 7.11 GiB (14.2%)
ID-3: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
used: 7.11 GiB (14.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.71 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Memory: total: 8 GiB available: 7.71 GiB used: 1.35 GiB (17.5%)
Processes: 318 Power: uptime: 18m states: freeze,standby,mem,disk
suspend: s2idle avail: shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 3.07 GiB
services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 257
Packages: pm: pacman pkgs: 1105 libs: 362 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
running-in: gnome-terminal inxi: 3.3.37
System install date: 2025-04-12
Last full system update: 2025-04-12 ↻
You did not reboot!
bogomips: 27999
Local Storage: total: 50 GiB used: 7.1 GiB (14.2%)
scheme: MBR
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 7.1 GiB (14.2%)
ID-2: /home raw-size: 50 GiB size: 50 GiB (100.00%) used: 7.1 GiB (14.2%)
used: 7.1 GiB (14.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
or lm-sensors.
Memory: total: 8 GiB available: 7.71 GiB used: 1.19 GiB (15.4%)
Processes: 365 Power: uptime: 0m states: freeze,standby,mem,disk
services: gsd-power,upowerd Init: systemd v: 257 default: graphical
Ok, if reboot dos not fix the problem start
garuda-rani
from terminal and post the log file.
BTW, did you use the -git version?
I solved the problem by rolling back the mesa version via downgrade, thanks for the tip.
From
Our distro is optimized for performance on real hardware. Installing in virtual machines is not recommended as it may result in a bad experience due to the missing graphics acceleration.
